Wheel bearing help
The hubs on my car that the wheel studs are attached too have a bit of play when I move them around. Does this mean I need to get new wheel bearings? Or when I put the wheel on and axal nut it will tighten it all together.
  • NZ-DB8RNZ-DB8R Moderator
    Yea it will tighten up when you do up the Axle nut. As long as the bearing roll smooth they should be alright
