Soft Brakes and Erratic Idle
Hey guys, like the title says I have incredibly soft brakes and my idle will jump up about 500-700 rpm. I've noticed the brakes arent soft when the engine is cold and the idle doesnt jump around when its cold either. I was told that the brakes could be soft because of the idle. But it sounds to me like a bad master cylinder. Any ideas?
It is possible that a faulty master cylinder is contributing, an extended stroke could expose a crack in the diaphragm.
As a start, I would recommend bleeding the brakes just to be certain you didn't get air in the system as it's easy and inexpensive. As far as the idle goes, sounds like a vacuum leak or your idle air control valve is having trouble finding the correct idle. That can be caused by low coolant or a dirty IACV. Make sure your coolant is full and search a how to on cleaning the IACV.
