check engine light issue
Low_Lyfe
Wagonist
Hello everyone. My check engine light keeps coming on in my 89 wagovan, and I would like some advice on what it could be. When I first start the vehicle up the light doesn't come on, it takes about 20-30 minutes til it illuminates. I just did an oil change, and replaced the fuel cap. Also I took it to autozone to see if they would test it for me, but they said it was to old of a vehicle lol. Anyway I was just curious if anyone could help me further with this problem. Only other things I can think of would be bad spark plug/and wires or the coil pack. Is any of the items a common issue with the wagovan? Any and all help will be greatly appriciated.
Thank you for that advice, I actually just bought some spark plugs for it. Im going to change them real quick and if it doesn't fix it, I will be sure to do that. Thanks again for the advice. I will get back to you on the issue, if I cant resolve it myself
For starters, why in the hell did it take you two weeks to pull back the carpet and check the code? Fixing your car doesn't seem to be a priority...
Second, you don't have an electric VSS. So you're getting bad info, whoever told you that. The speed sensor has no connection with your ECU.
Third, quick google search says 17 is ECU. So if I was you, I'd get to a junkyard asap and try and find a new one. Or find a buddy that has the same one, and swap it to see if its fixed.
I didn't think it was that serious, being as the car really never had much service. Thought maybe it might just be bad spark plugs and wires. Anyway thank you for the info.
Thank you for that info, I called autozone and quite a few sites that all say the same as you. Its weird the speedo work fine, it just stalls for 10 seconds and then responds lol. Thanks again for your help darktrickster
The car stalls, or the speedo stalls? If the speedo stalls then there's your problem, jam it back into the tranny, or the gauge cluster, or get a new cable.
Yea like it lags once I start to accelerate,and then the check engine light only come on when the vehicles starts to slow down.
Ah dang, I do apologize. "It" is referring to the speedo. That would be great,fuel economy does suck lol. Thank you so much for the info. I do appriciate all the help you have been!
