Fuel gauge fluxuation
ok so the fuel gauge wasnt reading at all so i did some inspection and found out that the wires were cut and they rewired it and left it unplugged . so then i connecter the wires and the gauge worked. then after a while of driving the gauge kept going from half tank to full tank slowly. i drove the car for a couple of hours yesterday and it did it the hole time. im thinking the sending unit isnt getting a proper signal goes anyone know what might be the problem
this is after i connected the back up
last night
this morning
last night
this morning
Pull the senting unit & test w/VOM meter.
OR
If it keeps going up & down while driving.Disconnect the connector hook up a long jumper to the front of the wgn. to a VOM meter.Go drive around to see if the ohms go 2-39 ohms (around 2-5 is full.25-39 is 1/2 full).back & forth like your fuel guage did.
If it goes up & down....bad sending unit.
If steady eddie...I'd look at the fuel gauge.Depending on how & when the wire was cut.It may have blown the fuel gauge.
