90 rt4w d16y7 swap wont crank over to start
ok i picked up a 90 awd wagon shell i dropped a y7 with a b7 intake manifold, a crx si tranny, pm6 ecu and si engine harness. I bought starter, alternator, distribuitor, and clutch new at this point the motor is in the bay with all mount install harness plugged in and battery installed dash lights turn on everything powered works but it wont turn on it wont even crank..any suggestions????? can it be the main relay? can it be my ignition? if so how do i check? thanks
Are the wires match for match kind of thing?
Not all harness's were wired identical.
Is all the wires connected grounds etc.
When you say crank? Does the motor spin over? or no noise?
