Newbie having trouble removing transmission
Recently picked up a 89 rt4 wheel drive wagon and found there was a rod knock so started pulling the engine and trans last night. Having trouble getting the trans to drop out, have all the bolts ( that i can see ) removed, Its dropping very low but wont seem to slide of the engine fully. Any advice would be awesome. Thankyou!
C) If you've done above, probably need to give it a jiggle or get a pry bar between the 2 on both sides and force it out slowly, often the input shaft gets a little stuck
C) ive litterally had my buddy jumping up and down on it while ive been pulling from the pass side and it will drop super low and almost completly discconect from the engine but still wont budge >:( but i
There is bracket that attaches the exhaust manifold to the transmission. Did you unbolt that?
the jackshaft? you mean like halfshaft? my buddy has a the spare d15b7 sitting in his garage, from the research i have done as long as i swap the distributor, intake mani, and sensors i should be fine. read that the d15 will bolt up to the trani fine
thanks for all the help guys, i appreacite it
Yes the half shaft, jack shaft, intermediate shaft, mid-axle...whatever you want call it. A standard long axle from a FWD car will not clear the housing for the rearward driveshaft.
I read that the d15 should have the holes for the half shaft to bolt up, read that some of them don't have the holes tapped but I could probably tap them myself if it came down to it. Is this true? I plan on using everything from the d16 other then the block and head.
incase anyone is curious about the d15b7 swap after some research i found that th zc IS shaft and RT4 IS shaft is the same and found a company named hush performance that makes zc IS shaft Adapter brackets for any d15, so i went ahead and ordered one so the swap becomes as easy as possible.
i'll be making a build thread soon
