Rear toe need help
Hey guys this is my first post so im sorry if this was already covered. Im lowered about 1.5 / 2 inches on skunk2 coilovers and struts and i redid most of the bushings with ES.Took it to get aligned and My rear left toe is -0.05 and right toe is -0.15. the shop said that he ran out of factory toe adjustment. I know that my trailing arm bushings are shot. could this be the culprit? and if not what can be done to zero the rear toe?
example
I had some Blox toe arms but never needed to use them as the alignment shop said they wernt required, also by moving the whole bush across rather than forcing it with the toe arm the bush will last longer
Slotted:
[img][/img]http://www.jhpusa.com/store/pc/catalog/whiteline/whiteline.rta-bushing2_d.jpg
OEM:
