Fuel pump?
JDM831
Wagonist
hey guys couple of days ago my car died while driving it had power but i can here the fuel pump prime so now i need fuel pump but in stead of buying new one i cant afford it want to grab one out of the junk yard now there not to many wagons there so my Question is witch fuel pumps will work out of witch honda's
i replace the timing belt dizzy around the same time about 4 months ago . and yea i ment i cant hear the fuel pump prime . and i check my fuse there all good still. ok ill look for thoese civic an integra and see what i can find thanks for the info
Any ef civic, crx, wagon, 88-91 full assembly will fit.
That is for the 2WD Wagons. The RT4WD have a different pump assembly, but it should still use the same fuel pump.
Mine is a 89 RT4WD...
The alternator isn't getting enough power to the battery causing it to be very low. (happened to me on my old crx) I changed it and it worked fine after that. It could be something stupid also. Idk why the oil light would come on unless it's really really low on oil...
