Fuel line flush???
As I was changing my fuel pump in my wagon I happened to glance into my gas tank and saw a shit ton of pine needles and small twigs... Yes that is what I saw. Don't know how and don't want to know why.
So I cleaned it out as much as I could (without dropping the tank yet)
Now my question is how can you clean out the fuel lines? I feel like there is a lot of dirt/pine pitch in the fuel line still. Is there any special chemical/fluid I can use to flush it out?
I was thinking I can disconnect the line on both sides fill up the line with something and blow it out with an air hose? Or is there a better way to go about this situation.
I honestly think someone did not like him and put it in there OR someone before him replaced it and it sat or something. I'm confused on why also.
I was planning on just throwing in the new fuel pump and change the fuel filter for now. Hopefully it won't clogged up within a couple weeks. I really have no time to do anything major right now but I will eventually drop the tank and do a full clean in it.
