94 integra springs on a 90 2wd wag..
Hello wagos!! Well I have done the hunting like numbers of wago owners the perfect wag suspension combo.. I have some skunk2 lowering springs off a dc and want to put on my wagons stock struts. Is this possible? Im only looking to lower for more control and never been a fan of coilovers.
keep in mind used or new, if you are running stock struts they probably will not hold up to the lowing springs in the long run.
might look at aftermarket teg struts to do it right and keep in mind you are gonna need the front forks for the front teg struts to make em work.
I'm running stock teg springs on tokico blue teg struts, lifts the wagon just a hair and is a stiffer ride.
In the past i've ran lowering spring on tokico blues as well.
