airodeck's 1991 EE wagon build
Hello everybody!! Been lurking on here for a while and finally got a wagon!!! have had three accord ce1 wagons ( hence the user name ) but am really looking forward to building this civic wagon with a budget of 8-10 grand.... first 3 photos is how i got it with a blown up d16z6 motor... have been pulling it apart and the bad motor eli and i are pulling out sunday!!! plan include bodywork and paint, going to paint it 2006 honda element tangerine mist metallic ( yr-563m ) b16 swap,coilovers, full color change to interior, and some nice 16" wheels!!! i will update as often as i can and any help or opinions from u wagon guru's will be much appreciated!!! GOD parts are hard to find for these cars!!!!!
lol... will put about 8- 10 grand into her... my last car ( had about 15 grand into it ).....
thanks....
got some vans amber lens spray and sem trim black and restored my corners!!!!
got some metal work started... filled SHUTTLE mid wing holes, filled emblem and rear wiper holes, lower keyhole, and mated the lower tail light filler pieces to the body!!!!!! (and got my jdm tails from japan today )
and finally got all the sem products to start changing the color of my interior!!!!!
not going as quick as i would like but i'm making progress!!!!!
Whats the difference with the JDM tails?
all amber on the side
I've had better luck with the Bulldog adhesion promoter, as compared to the SEM stuff, but that's just me:)
for the interior stuff?????? doing a complete color change from blue to tan and brown....
thanks.. it will be getting a lot of work done to it this winter!!!!
sure did!!! hopefully will be body worked and primed soon!!!!
also removed all brake lines, proporting valve, and wiper motor and arms and shaved all the holes!!! wiper cowl is also being completely shaved with fiberglass as we speak!! shaved off oem fuel filter bracket ( will run one in-line underneath car ) brake line tuck will hopefully be done this weekend, also will reroute the cable to hydro line, and then body work will start on the bay, primered, and sprayed!!!!!
How did manage to take the back seats out?
The part I'm having a hard time taking the backrest bit out (the bit that folds up and down).
I can't seem to locate the bolts.
Will take a look after work.
Loving the tucking going on here, more on the wiper motor?
http://www.tunersdepot.com/Lighting/Lens-Painter/Vans--Lens-Painter---JDM-Amber-Spray-Tint--110ml--95142.html
Going keyless entry? And thank you for the link sir!
