B series A/C ?
lilROOKZ
Wagonist
Does anyone know how to get A/C in a b series swap? Im not sure if i have the room to do it, but i need A/C Texas is too damn hot!:mad:
:smug: good luck
ok so you have b series and AC, i dont have a half core just yet guess ill put that on the list. Honestly ive been thinking of doing something like what the old school rat rod guys do something like this http://www.amcpacer.com/images/kenosha/kenosha-15-window-ac.jpg
Its really simple to just use the honda one and it lines up perfect
Im pissed i didnt put ac in a long time ago it was easy. the Bswap is going to be just a bit of work.
Yeah i hear ya man im so mad at myself I didnt just do the A/C when I was doing the swap. At the time tho I was living in Indiana and its tolerable there, but Texas. NO WAY! I need A/C and I dont need 3 cars so, looks like im gonna try to make this work!
Thanks guys!!
Uses all of the stock lines, fans, radiator etc.
Yup ive seen that kit too, I got bored one day and modified the stock one and it lined up really good
Thanks bam-bam I'm gonna check into that kit, I've got the stock radiator with slim Mishimoto fans, so hopefully I can squeeze that compressor in there.
Gonna check this out more tomorrow at work!
Only thing that's gonna kick my A$$ is the fact that I just bent till they broke the stock A/C lines. -____- you live and you learn I guess.
If you wait till the 5th i can get you the lines cheap. ecology is having half off everything here in san diego and send you the orings- enough to do the complete system. just let me know.
innovative and hasport mounts do make the bracket just know what compressor you have because they both work with the sanden but only one works with the matsushita compressor i think. you can keep the full size radiator but the slim fan may or may not fit. the fan is needed so it may need to be put in front of the condenser.
Good luck!
PM me
thanks
tech 8 lines but the last one is part of the evaporator, it hooks to the expansion valve and i count it as oart of the evap unit.
LMK
I paid 130 for everything "compressor, evap, harness, fan, condenser, lines, every nut bolt clip and then some" so guessing 30$ but dont quote me- Ill just buy them anyway and let you know the price so if you dont want them I have another set. its also half off that day :smug:
Honestly though if I were in that situation I'd just get that P54 bracket that way you can use all D series stuff, we know what we need for those and it would likely fit up a bit easier.
"you can use either a del sol p54 or a crv p7h"
Looks like they might both be the same part number, so that gives you some choices if you're doing the pulling yourself. I also saw that there was an aluminum bracket off a type R integra that fits and is lighter weight, if that's of any concern, so that might be an avenue to look into as well.
I'm definitely not claiming any validity to this being 100% for certain as I've not done it myself and just did some searching. The part number for the P54 bracket though is 38930-P54-000 and I wager there's some other idler stuff or what not that goes on it that you'd also need.
I did find this as well though in hunting around which is also in reference to D series compressor on B series motor:
These are the correct part numbers to put your D-series compressor on your B-series motor:
38930-P7J-000 CRV Bracket
38930-P54-000 Del Sol Bracket
So if they have a 2000 CRV in there, that would indeed be it. Like I said though, don't blame me for anything that doesn't work please =D And if it does, well please document with photos along the way so we can have that here for reference. Do a writeup on it and it would be a great thing to get added to the quick links.
As far as the rest of the AC system, you can pull it from any 88-91 Civic, but be sure it's the Sanden compressor a d not the MatsuSHITa.
The remanufactured kits shouldn't have a problem. I'd just buy from someone who has a decent warranty on it. Any fresh hoses you buy should come with o-rings. You can get o-ring kits anywhere though.
Does anyone know what type and size belt to use???
