#14 Fuse goes out
 GeNX
                Wagonist
GeNX
                Wagonist
                    OK so my # 14 fuse keeps going out. It's the ol Alternator Selenoid Pump fuse. The engine just turns and turns and won't start. I don't think it's the fuel pump. If I disconnect the Alternator plug and replace the fuse then the engine starts up no problems.
UPDATE: I put in an OBD1 alternator and no blown fuse #14. So I guess it was my alternator shorting out. Also the battery light wouldn't light up on the dash and now it does. No clue why. I wish I could use the OBD1 alternator with but it has a different pully/belt that is not interchangeable withtthe original. So now I have to find a replacement or rebuild the broken part.
About 2 am I had an epiphany. If I have a 3 rib belt why can't it fit on a 4 rib pulley? So If it works great I didn't have to buy a new alternator yet. If not i'll let you know how long it lasted.
