91 wago auto question
 Gringo Van flipflip
                Band Wagon
Gringo Van flipflip
                Band Wagon
                    So my mother in law pops over with her 1991 wago (i'm supposed to put a deck in for her) I get into the car and i notice the park light is illuminated....
Wierd eh, key is out of ignition and car is in park.
So i put key in cycle thru part to D2 and back and turn ignition off slowly and its all good.
Put radio in.
start car check stuff and drive around the block, and park......key off........lights on again.......cycle gears, play with switch nuttin still on.
Get out of car and notice running lights are on? can't turn em off, cycle more and more on gears and ignition switch......still on.
So im thinking ignition switch worn causing daytime running light module to stay working?
Played with the idea of safety neutral switch but car locks in park, must depress brake and gears all select and highlight in cluster?
what do boys think?
Put radio in.
what do boys think?
Started pulling fuses and have just pulled the daytime,radio,cigarette lighter fuse out and prob is solved
Just for now. Im leaning towards headlight switch being buggard but questioning power being to the shift selector colum? Im thinking power is on perhaps due to ignition tumbler?
So pulled some others, got to cigarette lighter, clock, dome light and instrument cluster......went out.
So now no power to radio and clock and dome light......turned headlights on and radio and clock work..........
Its the combo switch. wierd eh?
