my 89 RT4WD build
Just bought an 89 RT4wd with a DOHC ZC and a manual trans in it. I'll be picking it up tuesday. Some rust around the wheel wells but the underside is strangely solid. Previous owner might be a member on here.
Here's the specs so far:
Engine:
DOHC ZC
Bored 0.5mm over
NPR P29 Pistons
ARP Rod bolts
new honda head bolts
fresh valves
head skimmed
Cometic Head gasket
Crank polished
King rod and crank bearings
AC removed
needs rear main seal to be re-done at some point. Still driveable just have to keep an eye on it
suspension/steering:
Depowered power steering rack
DC rear shocks/springs
DA front shocks/springs
Interior:
EK armrest
Blaupunkt head unit
6-1/2" front 3 way speakers
6x9 rear 3 way speakers
Exterior:
custom roof rack
Tire/wheels:
stock white steelies with snow tires
Pics from the classified ad is all i got right now
More to come the plan is to turn this into an autocrosser. There's going to be some work done to it but i leave for basic in less than a month so it will slow down for 14 weeks then speed up again to hyper speed buying parts during AIT then installs when i get stationed
Engine:
DOHC ZC
Bored 0.5mm over
NPR P29 Pistons
ARP Rod bolts
fresh valves
head skimmed
Cometic Head gasket
Crank polished
AC removed
Interior:
EK armrest
Blaupunkt head unit
Exterior:
custom roof rack
Tire/wheels:
Oh, and a good set of pads and rotors so you can stop effectively!
But sadly, due to weather and time constraints I still was not able to pick up my civic.
I will be getting it on monday. Its really starting to sink in how little time is left before i leave.
I picked up some odds and ends for the suspension, hopefully I can get this stuff put on before I leave, I got:
-4 generic ebay extended top hats
-Springtech front camber kit
-Godspeed rear camber kit.
Hopefully this combined with the new springs with the adjusters will let me switch from autox to rallyx without much fuss.
I'm going to do a few small appearance things to.
I'm getting the factory wheels powder coated bright pink, and I got Drop Engineering gold lug nuts for the heck of it. I ordered both SCCA contingency decal packs (autocross and rallycross) with magnetic backing.
Somewhere around here i have a few Grassroots Motorsports Magazine die cut decals and some bumper stickers. When I find them they're going to go on the car also.
I have a headlight restore kit that's been laying around for a while I plan to use it on this car.
I am going to try to make some patches for the holes in the seats out of some pink grey and white camo material I found. I was hoping to re-cover the headliner but I don't think I'll have the time.
the carpets look pretty bad but under those floormats is spotless
I spent all morning trying to figure out how to get these cross-bars on
It seems to sit higher in the front but now for long...
So my drive home or first impressions of the car were that it was fun to drive, the motor is happier in a higher RPM range than I'm used to, and my brakes are junk.
I took a run to the local parts shop and the guy behind the counter seemed very excited about the car. He offered to pay me blue book value for the car but I told him I had just got it home, and I didn't think he'd be able to find it in the blue book. The pads were a special order so they won't be in for a day or two. I was half expecting they would just be the same pads as a crx or a civic hatchback.
I haven't made any other progress besides exploring the car a little. I fiddled with the radio and cleaned it up a little other than that I'm stuck waiting for parts.
The previous owner included a full hard cover shop manual with the car, and i found the original owners manual in the glovebox. One of the keys he gave me was also an original. Its the key i decided to put on my key ring I like how old and worn down it looks.
Id really like to get me a 5speed one
