Wagon window seal?
I've had a bad driver's side window seal on my wagon for quite a while, but cant find any aftermarket replacements. Should I just take a chance on an ef 4dr seal?
    I have a 4dr window seal on my wagon. You'll have to stretch it a bit but it does fit. Now....no more leaks for me :D
  • Ajr49123Ajr49123 Band Wagon
    Ok thanks for the response
  • are you referring the glass run channel or the door weatherstrip?
    I found the glass run channel from www.hondapartnow.com for like $40. they delivered it super fast and only took me like 20 minutes to swap the new one in.
    They also sell the upper weatherstrip for like $27 but no luck with the weatherstrip itself though; let me know if you do find one as I would like to replace mine too.
  • http://www.hondapartsnow.com
    The S was left out :D
  • 83battlewagon83battlewagon Band Wagon
    how much stretching is needed?
