Engine Harness problem....
 RE*Done
                Band Wagon
RE*Done
                Band Wagon
                    I'm in the middle of doing a swap and wire tuck and just noticed that the engine harness on the drivers side plug has an extra wire. I don't have the original engine harness that came with my 88 wagon so I had to go to the junkyard and pull one off a 91 Civic hatchback. I thought it would be the same but it isn't. The drivers side plug from the cabin has 11 wires and the one coming from the engine has 12 wires. Is there anything I can do to make this harness work? I don't want to go back to the junkyard cause all I seen was 90 & 91 civics.
I am looking at the 1991 FSM and it shows the DX and 4wd/AT has 14 connectors. This is the big connector near the injector resistor pack.
The 4wd manual has 8 connectors.
Just keep in mind there is a difference between auto and manual.
Mark
