1990 rt4wd : find my main relay
 AldPixto
                Band Wagon
AldPixto
                Band Wagon
                    car: 1990 honda civic wagon D16A6 AT RT4WD (unmodified)
I suspect the EFI Main Relay is causing my intermittent start problem : car starts when cold but intermittently won't start after its just been driven. The car will restart after its cooled; this could take one minute on a cool day or an hour on a hot day. I've done soldering before - so I'm comfortable with re-flowing the solder joints on the relay board to see if that will cure my problem.
I know what a relay looks like, and have seen photos of the main relay on this board, but I can't actually locate the relay under my console. Is there some carpeting or plastic covering I need to remove?
Here's a link to some 'panoramic' photos I took:
http://www.flickr.com/photos/20947021@N08/6277645967/in/set-72157627846099271/
Can someone point me in the right direction? Like drawing an arrow on one of the photos I've posted.
Thanks in advance,
Ald
Thanks in advance,
Ald
Do I need to remove something to see the relay?
Do I need to remove something to touch it?
here's another picture of what I can see: http://www.flickr.com/photos/20947021@N08/6278518761/in/photostream/
Finding this relay may be obvious later on, but for now I'm reminded of a VW service manual saying to "rotate the nut counterclockwise then remove the fan". The service manual neglected to mention a 4-ft breaker bar might be useful because the engine cooling fan on the VW bug is really held on there.
Honda's factory service manual has a line drawing showing the relay is somewhere between the fuse box and the body. Honda's electrical troubleshooting manual has a useless very tiny picture showing the relay with no clue as to what perspective the camera is looking from. I don't know if the relay socket is parallel to the ground or whether it is on the top, bottom, or side of the relay.
thanks
You will have to feel like you're artificially inseminating a cow before you're close.
I had to loosen the dashboard cowl and separate it from the driver's kick panel area to see the EFI main relay.
* I made the mistake of unbolting the relay mounting tab from the car and later found that I couldn't hold the 10mm bolt straight enough to reattach it. I ran a zip tie through the hole in the mounting tab and the threaded hole that originally held the screw. Sigh.
My repair passes the smoke and burn test. Since I never bothered to try to scientifically reproduce my problem (e.g. like using a heat gun or hair dryer to force a failure) I'll just have to wait until the next big heat wave (or cold wave) to see if my intermittent problem has gone away.
relay location photo: http://www.flickr.com/photos/20947021@N08/6284393311/sizes/l/in/photostream/
Thank to bam-bam for my getting warm clue and general encouragement from everyone else.
