Can an Auto P28 work with a stock RT4WD transmission?
So after searching and not finding an exact answer I am curious if the following set up will work?
D16Z6(long-block)
RT4WD auto transmission
OBD1/VTEC conversion
P28 (Auto)
I am asking specifically about the ECU, I am aware of the process to swap the D16Z6 in... Thanks!
D16Z6(long-block)
P28 (Auto)
"An auto P28 will run the engine and properly signal the Interlock Control Unit. It will not control the lockup solenoid properly, so yes you will need to wire up a signal of some sort.
You will also need to either make a pair of resistor dummy-solenoids to make the ECU think it's connected to something, or bypass the lockup solenoid driver ICs inside the ECU (the cleaner solution if you know how to solder/desolder PCBs). The car will still drive okay if you don't do one of the above, but the check engine light will be on all the time." - bobski via CRXCommunity.com
"TC doesn't need locked, but you will lose 2-3 mpg, but IMHO the car cruises better!
288k on my 91 Civic EX with Y8 motor swap installed by previous owner." Mista Bone via CRXCommunity.com
