Door Lock Actuators, where to mount them?
 1Fastboy
                New Wagonist
1Fastboy
                New Wagonist
                    So I got a set of actuators and lo and behold I cant find a spot to mount them..ah!. Just poking in the searches, I couldnt find any pic's of other installs. If any one happens to have some examples it would be awsome. i'll post up my install as soon as I figure it out.
but its not the case and you still need clearence for the throw.
Are you actuating the door lock knob or the inside handle rod? Im assuming you mean the knob. With the door shut and locked you have to manually pull the locking knob before opening the door via the inside handle. So attaching the acuator to the inside handle (rod) would not unlock the door....I sure im stating the obvious here but just trying to be clear.
Arg.... :x
I dont like the way they slam the lock open and shut just my personal opinion. but they do work good.
there is no problem with the throw the arm in the actuator moves about and 1' to 1.5' " find the happy medium because if it pulls down to far you will be fishing for the knob.
I hope this helps you out.
