My Wagovan Sometimes Does not Even Crank to Start! Help!!!!
 Reaccion
                Senior Wagonist
Reaccion
                Senior Wagonist
                    Problem:  Hello guys! Something is happening with my 1989 Honda Civic Wagon Wagovan. My wagon does NOT start sometimes. I mean, the wagon does NOT even crank. It is like if the ignition switch would not be working properly. I changed the ignition switch but the problem continues. I get a positve cable from the battery and with the ignition switch on, I jump the starter and the wagon starts right up. Also, when the problem occurs, there is a clicking noise coming from under the steering wheel around where the fuse box is around. I am thinking that it could be a blown relay or remote starter cable. Please let me know your suggestions!!
Solution: I found the problem. There was an remote starter alarm installed by the wagon's previous owner. This alarm is still installed on the wagon but is not functional. There was a relay for the remote starter between the starter and the starter switch. I just eliminated this relay and I was good to go!
the clicking noise is under the steering wheel... The starter works just fine right after jumping it....
Yes, I replaced that already.... But the problem is still the same....
Yes, I am guessing that there should be a relay or something that is going bad....
Check the idiot switch on the clutch pedal if it's a manual.
LOL... This is automatic...
When I bought my wagon, the PO had run some wires from under the hood (battery & starter) through the door jamb to a switch sitting on the dash to start the car because "the ignition switch was bad". Turns out, the little plastic button om the clutch pedal that works the switch was gone (just like when the brake lights stay on all the time.)
I'm rambling - take a look at your wiring diagram and see where the circuit get's interrupted.
good luck - I hope it's an easy fix
Thanks man... I checked the wiring diagram circuit between the ignition switch and the starter and I found the problem. There was an remote starter alarm installed by the wagon's previous owner. This alarm is still installed on the wagon but is not functional. There was a relay for the remote starter between the starter and the starter switch. I just eliminated this relay and I was good to go!
Happened on my hatch a few months back, same noise you're getting
Happens on my wagon I bought a week ago same noise etc. Hitting the starter gets it to crank. So this is something I've seen more then once.
If it turns out to be your main fuse relay which I doubt let me know I have a few extra I'd let go which I know work.
Thank you. However, I found the problem. There was an remote starter alarm installed by the wagon's previous owner. This alarm is still installed on the wagon but is not functional. There was a relay for the remote starter between the starter and the starter switch. I just eliminated this relay and I was good to go!
