anyway to check A/C compressor?
 wagodizzle
                Council Member and EDM expert
wagodizzle
                    i am about to tackle putting a/c into my car as the past few weeks of it being in the high 90s and low 100s has got my brain melting. over the past like 3 years i have slowly been collecting everything needed for the install, including FIVE different a/c compressors
so question is, is there any way i can tell which one works or not? i ruled out a couple that i know for sure dont work and are missing parts.. but short of installing everything and wasting a bunch of freon and headaches, is there another way?
i really do not have money to just buy a reman, and with used... well, im back to where i am now
If it spins too freely it's worn. If it won't spin, it's seized.
The pulley itself should spin freely with no resistance and no noises.
Check the clutch with jumper cables: Hook the ground to the compressor body, and the hot to the single wire going to the clutch coil. It should engage the pulley to the drive plate.
Drain the oil into a clean graduated container and examine it closely for any debris. The mineral oil in there was originally very nearly clear. It will have an orange or brownish cast, but generally darker oil is older. Note how much was removed, should be roughly 4 ounces.
If the compressors have been lying around, give preference to ones that have been sealed up. If they are open now, tape or plug the 2 ports.
i need that clutch plate Bam spoke of ...
:idea: so this saturday might just b the day of JUNK YARDing..... looking for a front bumper off something since i have been out bid on two different EF9 bumpers.. :x
my question is how simple is it for me to remove the clutch plate or hole pulley i need... :?:
Before you replace your compressor, make sure you have power/signal there. it would suck if all you needed was a fuse or a relay.
Thanks
