motor mount inserts will they work in the 4wd wagons?
im looking at some prothane motor mount inserts has anyone used theses on 4wd wagons? will they even fit?
http://cgi.ebay.com/ebaymotors/Prothane ... enameZWD1V
http://cgi.ebay.com/ebaymotors/Energy-S ... enameZWD1V
    I see no reason why those would not fit. 99% sure they will.
    100% sure 3 of them will.
    I highly recommend NOT getting them. They are extremely stiff and will cause vibration throughout the chassis. I have run these kind of bushings before. They take away from the daily drive-ability of the car. I would say RACE APPLICATION ONLY.
    Get some OEM replacements if yours are worn, if not, invest the money elsewhere.
    i dont mind the vibrations ive have stiffer mounts then theres before. i need them tho' my car is going to rip apart the stock mounts if i dont do something.
    Make your own with window urethane. Wont cause the extreme vibrations, and still help with overall motor flex.
  • JDMshuttleJDMshuttle Senior Wagonist
    i have them they are not that bad better then the ST 1's they should fit they need to be trimmed alittle if you have a dremel but other wise nice look and fill holds the TQ in place
