wipers don't work
HELP
I'm working on putting my 87 wagon , back on the road, my wipers worked at first, i removed the security system someone had put on it, no factory wires were cut, and now no wipers or washers. What is the best way to check for shorts, everytime I put a new fuse in , it blows it. If the wiper motor is bad will it blow the fuse. It worked for awhile, after i put the first new fuse in, shut the hood to pull out of the garage, started it back up , no wipers. any suggestions, also my hazards don't work.
Thanks
Roger
Thanks
Roger
Thanks
Roger
Roger
Check the mechanics.See if the bushings areOK.Any thing jamming or sticking.
There is a tool for checking shorts.It plugs or clips into the fuse.Then you go checking for the short.What it does is as it overheats from the short it turns the wiper on & off till you find the short.
There is a hazard relay in the '88+ so there's most likely 1 in yours.Try turning the hazard switch on & off several times.This sometimes cleans the internal contacts.
Good luck.
