Intermittent hesitation around 2-3k rpm
I have had my wagon for close to a year now and when I first got her she ran unreal, no hiccups or hesitation whatsoever. Then I added a quart of Seafoam to the tank like I've done twice a year to previous cars I've owned and I swear if it didn't make things worse. (maybe it was coincidence) Now I have this really bad hesitation right around 2-3k rpm mainly in 2nd and 3rd gear. It's a 6spd manual 4WD and it runs relatively smooth as long as I keep the RPM's up above 3k but it stumbles like crazy like it's not getting enough gas under 3k. It also happens in 4th and 5th gear but not nearly as often. I've noticed that it also seems worse when the humidity is high. However it gets better if I can get the car over 60mph for 30 sec or so- after that it's smooth again. So far I have replaced all the plugs/wires, cap/rotor, fuel filter and I even had a fuel sytem clean done to it which seemed to do the trick until I had to fill-up again and right back to square one. My brother seems to think it could be bad injector(s) or throttle position sensor. I also added another quart of Seafoam about a month ago to a full tank and it ran incredibly well til I filled up. I'm stumped, can someone please tell me what to try next?
