Stereo!?
I've recently acquired an 81 Civic Wagon, and I can't seem to find any sort of wiring harness for it to a CD deck.
What do I do?
Should I try and find the wiring diagram for the stock cassette deck, and the one for the CD deck I have and just hard wire it?
What choices do I have?
What do I do?
But yeah, anyways...
Would the wiring be the same as on an 85? That's as far back as stereo wiring harnesses go for Honda.
I seriously doubt it since 85 is the third gen, and an 81 is a second gen, but its worth an ask.
check out www.1stgencivic.com for tons more info
Only needs 3 wires to turn on, Permanent +12V, ACC +12V and Earth. Other than that speakers.
In my brothers car with no factory headunit I ran a wire from the fuse box for permanent power, from the ignition for ACC and then just earthed it oh to the chassis. Done
if your not hands on type of guy
go to best buy they'll connect it for $45.00.
12volt constant, switched 12volt and ground.
then pretty much is is speakers.
I've usually just used either a 9volt or a AA. Touch the "lets say white with on one end with with white/ black stripe" listen for the muffled pop. And where it is coming from.
That will tell you which speaker. Your barely moving the cone doing this.
