My B20 vtec build
Current parts
ON B20 Block: je pistons 12.5cr, H-beam eagle rods, ITR oil pump, ITR water pump, Moroso oil pan, golden eagle oil filter b20vtec adapter
ON b16 Head: port and polish/5 angle valve job by portflow, Crower-dual valve springs, retainers, valve seats, and titanium valves,
Bump sticks: Buddy club spec 4's
The Car: 1991 Honda Civic Wagon (EE civic)
My Goals: To have a quick little daily wagon that I can take to the track on the weekend and have fun with. Shooting for >230-240whp. It will have a/c, and no ps.
Parts Needed: 440 injectors, 255lph fuel pump, Hy-Tech big tube header, 70mm throttle body, clutch and TUNING.
I will keep it updated when I can, parts are coming in slow, because along with this I am making plans to get married sometime this year (paying for ALL of the wedding because our parents are broke)
AEM cam gears came in today and just bought a skunk2 pro series intake manifold and a hondata IM gasket.
The reason I ask is you stated it was going to be a daily driver/weekend track.
First off, here in Texas we have 93oct
Secondly the tuner has had several >13:1cr run on pump
Lastly if 93 is not enough I will get bigger injectors and run E85 ---105-107oct (quite a few stations around here so its no biggy)
Having access to 93 octane and E85 just in case helps alot. Sounds like you did your'e homework.
What does the comp. ratio end up bein with that b16 head.....
Awsome build this should be lots of fun get some dyno and street vids of this when its finished!
B16
quench area is NOT flush with deck of head
GSR
quench area IS flush with deck of head
wasnt it shaky spear...
to be or not to be...
i don't know what you are talking about?
that's the point...
Just start, build it, ride...
nothing ever goes the way you planned...
Theories of a starting point, compressions, ratio's.
Parts wears down as you use it,
it needs a frequent tune...period.
I 'write' alot, cant elaborate about everything everytime.
Sorry
interesting point about those high octane gas stations...
where the f you want to go was I thinking...
that's all
My 650cc injectors, AEM fuel rail, inline filter, and fuel pressure regulator arrived yesterday. (650cc if I need to go e85)
I ordered the rest of my parts yesterday. Clutch, RMF header, Full race traction bar, and fuel pump. The problem is that full race is back ordered on their traction bars so I have to wait 30 days until one gets shipped out. But it looks like I will just finish the motor and install it and notch the cross member to fit the header so that I can take it to be tuned and break it all in before the traction bar arrives. I for see my wagon being in the 12-13's by next month. HOPEFULLY
lol
Gl
I also decided to do a DUAL tune, one tune will be for 93octane and the second tune will be for Q16 (is highly oxygenated, 3-5% more power than C16, 116 octane fuels).
The Q16 tune will yield about 20whp gain and in a N/A car you will feel it. I am HOPING for about 230-240 on 93oct and 250-260 on Q16.
