Windshield wiper arm stripped out
Hi
Has anyone come up with a way to remedy this problem, since Honda no longer manufactures the OEM replacement? The stem and nut are fine but the ridges inside the base of the arm are worn down, so the arm doesn't move with the motor. We put shrink tubing on the stem but I'm sure it's only a temporary fix.
I figure junkyard parts are ultimately going to have the same problem, at least eventually. I really would prefer not to use anything that will permanently fuse the arm to the stem.
Does anyone out there have a fix for this?
Thanks in advance!
