nope same swap. only time it gets a lil different is 88-89 and 90-91 and even then i thinks its nothing super hard. im gettin ready to do this swap myself on my 88 ill try to do a lil write up.
you can maybe make something to hold it up in there. i just tucked my wiring in there and use the wagon hood to hold it in works just fine. got my speedo working bad vss that i bought.
I checked out that link,it has good info on the wiring
I 'm concerned more about the mounting and appearance
In the link the guy said he didn't mount it to the dash, just screwed the cover on. Seems scetchy
I made 2 little aluminum tabs that screwed into the bottom 2 OEM Wagon mounts in the dash, and then screwed to the 2 bottom screw holes on the cluster. Too bad I don't have time to take it apart and snap a couple pics. Once you try it, you'll see exactly what I mean.
Overall, it fits extremely well. There's just 2 small gaps in the bottom corners that if you're really anal (I am) you'll want to fill in somehow (I plan to). Oh, and that wiring that TurboTeg linked to is spot on. I did the install about a year before I had the Wagon on the road, and it worked perfectly the 1st time.
i need to make some tabs so it will look a lil bit better but will have pics up in a bit ofit finished besides that. only problem im having now battery light came on and is flashing and making a beap.and i have no turn signals. everything was working just fine so not sure what that is gonna have to run through the wires again
Bumping an old thread, but the link turboteg originally posted no longer works. Does anyone have an updated link? Or any info on which VSS to use?
are you using the wagon cluster hood?
this is the link jaker gave me to help me with mine when the time comes.
http://www.tuner-junction.com/TJForum/h ... 1-crx.html
Ta.
