Puttin AC in the car that comes with no AC
What do I need under the dash and stuff? My canadian model didnt come with AC and I want to put AC back in it.
    Yeah I'm interested in seeing this done. Kinda wondering about if the wiring is in even when it's not equipped.
    Yesterday my buddy was removing the AC from his REX and i traded him some stuff for it. the wiring from what i can see isnt part of the car its a sub harness. once its all unpluged from under the hood go under the dash and remove the larger air duct behing the glove box that houses AC stuff under the dash. u will see a connector there unplug it and pull the wires through the fire wall. I kinda followed the harness into the car but havent gotten that far to actually seeing where it goes and how hard its gunna be to remove it. i should have some time this weekend to get it fully removed and i can let ya know how hard or how easy it is.
    Sweet! BTW I like pictures lol!
    Don't know about the Cad. mdl,but my USDM Wgn.had NO AC,I swapped one in from another Civic.It was plugNplay.
    thats good to know cuz i have a 91 EX that im gunna put the entire harness in a wagon but its missing AC i had a feeling i could add AC. ill try to get pics this saturday for ya guys but it looks like its possible.
  • When I bought my car the compressor and engine bay lines were gone. I just pulled the rest so I'll post pics.
    Here's everything except the compressor and main lines.
    So I just stuffed ac into my wifes wagon and it worked out pretty well! I had to solder and heat shrink a bazillion wires to fix the previous owners mess but it works! I even did a R134a conversion.
  • UPDATED
    AC condenser. You might want to buy this new. If you buy a new one, you'll need to get the upper isolator mounts from the junkyard.
    This is the AC fan and the side shroud.
    Drier. You may one to get this new since it will improve your AC's performance. And it's a must if you convert to R134a. You'll need to get the mounting bracket from the junkyard.
    This is the wire harness found under the hood, including the firewall grommet where it connects to the evaporator under the dash. This also includes the relays.
    This is the evaporator and mounting brackets which you swap out for your non-ac tube under the dash (the box connecting your blower to the box that selects fresh or recycled air). Make sure you get the drain hose and firewall grommet.
    This is the compressor mount and belt tensioner. That reminds me. You need the belt (duh).
    You'll need to cut open a harness just above the ECU and remove the harness and wires that plug into the engine harness and go to the AC button.
    I don't have a pic of the compressor or under-hood ac lines. These were missing when I bought the car.
    If you follow the wires and lines carefully, it will lead you to each component in the system. If you pull everything carefully then it's all plug n play (except to charge the system of course (good luck finding R12, better to convert to R134a)).
    www.civicwagon.com
    www.civicwagon.com
    www.civicwagon.com
    accumulator or drier depending on which side of the condenser this is hooked up to (I'd have to look that up).
    www.civicwagon.com
    www.civicwagon.com
    This is the evaporator and mounting brackets which you can swap out for your non-ac tube under the dash.
    www.civicwagon.com
    This is the compressor mount and belt pulley.
    I don't have pics of the under-dash harness going from the evaporator to the ac button because I haven't ripped that out yet.
    I also don't have a pic of the compressor or under-hood ac lines. These were missing when I bought the car.
    If you follow the wires and lines carefully, it will lead you to each component in the system. If you pull everything carefully then it's all plug n play (except to charge the system of course (good luck finding R12)).
    Now what I'd like to know is whether a R134a compressor from a 94+ will bolt up to wagon compressor bracket. I suppose the lines might be different, but I could have someone fab adapters. I'd rather do this than run R12 or run R134a in a R12 compressor.
    The compressor from an r12 system will work fine, They're the same thing just with different hose connections so as long as you can fit it and hook it all up go for it. If your going up to R134a just pull you old ac pump and turn it over. Cyle the pump by had a few times and let it drain out the thick goopy oil, repeat about 15 minutes later untill you get no more oil out. then refill your compressor with PAG 46 about 4 ounces, might have to cycle it a bit to get it to fit in there. Also, tip your dryer/accumulator over and pour out any excess oil and keep your dryer accumulator in a zip lock bag so the desiccant doesn't get excess moisture in it. Another thing to do before you slap it all in there is replace EVERY SEAL on all the lines, just trust me. Then get some ac flush that is solvent based not oil and flush out everything except the dryer/accumulator and you ac pump. You can use an air compressor to blow the flush through the system and do so till your getting nice clean fluid out the other side. Keep running air through it until no more fluid drips out and put it all back together. Do make sure you get your system vacuumed for at least 30 mins and let it see if it holds a vacuum. You should be ready for R134a at this point. Just figured if I can help you with this I might save you tons of time and money. If you have any questions just ask please.
  • Is your first sentence a typo? I think you meant to say "The compressor from an R134a system will work fine...".
    The original compressor and hoses were missing when I bought it. I'm keeping the remaining pieces for when I have the motivation to try fitting an R134a compressor. I don't want to put R134a in an R12 compressor because it's not as efficient. I assume I'd want to do the steps you outlined anyway... just to clean out the compressor before I install it. I'm bookmarking this thread for when the day comes.
    No it wasnt a typo and I have r12 compressors on my wagons and they work just like the R134a compressors out of the newer honda's. The newer compressors will bolt up, but the lines wont work. i used to think the compressors were different too, but it turns out it's the evaporator and condenser that are made for r134a. I need to dig up the source that I got that from though so it will make more sense to you. Another thing that will help alot is just buying a new dryer, it makes a big jump in performance especially if you live somewhere with moisture.
  • Thank you for that info!
  • 89ac_EE289ac_EE2 Wagonist
    good info for sure i'm going to go to a salvage and pull all the ac stuff out of it this weekend
    Yeah, having ac is so freaking sweet!
  • So I ordered a new condenser, drier, and O-rings. I'm going to get a compressor and lines from the junkyard. There were a bunch to choose from but there's this 91 sedan that's super clean that I've been pulling parts from. I'm going to let the shop flush the system and put new oil in the compressor since I don't know where to buy PAG 46.
    I haven't found an AC shop yet. This is the part I dread. Finding an honest, affordable shop that does things right. I much prefer to do as much work as I can myself. For instance, this car needed a new wheel bearing but I just replaced the whole knuckle instead rather than go to a shop that has a press. I went on 50% off Wednesday and got one for $16! 50% off day owns my ass and that's when I'll be getting the rest of the compressor.
    All of this because of a road trip on the 18th that includes driving through Nevada 110 weather with 5 of us including the mother in law. Tomorrow I'm getting all the windows tinted.
    Yeah, it's hot down here too! Just went through salt lake though and that seemed really nice and cool.
  • Thanks for this in depth info on R134 running :)
    Over here A/C was a dealer fit option, so not surprised the loom is a sub harness for you guys too for consistancy.
  • Yeah Salt Lake's pretty cool right now. It gets up over 100 in the summer on some days. I can live w/out AC, in fact I never run it on my Integra. But the wagon is for my wife. But besides that, we're taking a road trip through Nevada which is 90 degrees AT NIGHT. And we're bringing the mother in law...
    I'm going to finish putting everything back in today. I just got the new condenser. I'm still waiting on the drier and O-rings which were special order. I'm getting the AC lines and compressor on Monday when they're half-off at the junkyard.
    Sweet!
  • Bad news. Apparently my core support is warped. The new condenser wont fit. I don't like to rig things up so I may sell my AC setup or maybe hang on to it in case I find a clean wagon shell one day and swap everything over.
  • civicking1990civicking1990 New Wagonist
    Check this out maybe it would help. . .
    http://www.performanceforum.com/wesvann/honda/ac/ac.html
  • So the least you can get away with is by replacing the drier and emptying all of the old oil out of the compressor?
    Do you replace the drier with the EF part or with a one from a later car running R134 ??
    The Beagle was made till 1995. R12 was banned in 1994. DO you think very late Beagles run R134 as stock, in which case there are R134 parts available specifically?
  • Well the drier is fairly universal looking with a removable ring clamp around it. If the hose connections are in the same general location then you could use a drier from a newer Honda, swap the ring clamp onto it and drop it in.
    How I interpreted it was that all driers are the same regardless of the type of refrigerant... I thought he was just saying that you don't want to take a drier that has been used with R12 and start running R134a through it. It wouldn't be ideal. So get a fresh drier. I could be wrong though. But now that I've given up on AC since my core support is warped it's mostly irrelevant to me.
    Yeah, i used an ef9 sedan drier. It's just that the drier contains a desiccant that removes moisture from the ac system. After 20 years of service and having it open to the air for a few days in a moist environment and that desiccant is toast. It'll work for a little while but as the system chills the moisture will freeze up into ice.
    New drier is definitely an easy way to keep cool in the heat.
  • Cheers.
    I'll pop down to Honda and assume the position over the counter whilst learning the price of that one.
    well i got all the lines, evap, condensor, compressor and he fan and all the wiring into my canadian model and it works great. i fucking love it i had it turned down to the lowest setting and it was still to cold
  • New EF dryer unit from Honda UK.....
    $450
    :lol:
    All 3 of my wagons have very cold AC, I haven't bought anything new but oil and refrigerant. I did put a junkyard condenser on my swapped car.
    If you have a vacuum pump and some time, you can reuse the dryer. Heck, a basic vacuum pump can be had for $139...
  • I can't get my a/c to work. I got all the wires and relays and a other a/c switch and still can't get it the work. I wire it up manually and charge it but when I rewire it to stock it doesn't work.
    I thought it had some dessicant in there which wets out over time. Are you saying this can be refurbed?
    How do you go about doing that? Genuinely no idea and really would love to know fo the sake of $450 x2 cars !!
