How Many GSR Wagons?
Post up if you got one.
I am thinking of pulling out the turbo z6 and swaping in an extra gsr I have but wanted to see how many gsr wagons are out there. Probably end up adding a turbo to the gsr too as I have one laying around.
turbo_teg
Those are the 2 that come to mind.
And cmyrex i think
Yes the hardest part will be the trans and probably the drive shaft. His was just FWD so there was no need for any of that, but I believe you will need a custom made drive shaft.
I believe there is one in the junkyard next door to my Uncle's junkyard.
and just to confirm wagon axles are bigger in every way except the slines in the hubs so next time u hear some ass clown talking about how CRV drivetrain is bigger and tuffer than rt4wd parts tell them they are full of shit.
x2. CRV axles look like toothpicks compared to the wagon axles.
Oh, and I meant to tell you last night, I have an idea before you do this to strenghten them up a tad. Hit me up when you get a chance.
what car are u starting with is it already an RT4wd or a front wheel drive with a b sereis in it already.....
No, I'm starting out with a front wheel drive, 5 speed manuel, completely stock.
thats kinda a quick lil parts list your also gunna need to modify the tranny mount from hasport and the mount on the unibody, the axles will need cut down to work, and the driveline will need to be shorter as well.
theres more involved but thats a good start i didnt do the swap in my wagon but i have made a CRX 4wd with wagon parts its kinda the same process.... shenrie should be able to fill in the blanks on the swap info but go ahead and ask me anthing u want.
