+++SiWagon FYI: '88-91('96)JDM Wagon Options & PARTS.
Last Update:9/05/14.This will be updated from time 2 time.(Check RED hi-lites for lastest update)
Options vary in different countries.Click on Blue hi-lites for link.
Check out posting #71 for pics of many of the accessories .
ABS
Armrest:See Center Console.
Accessories:Misc & interesting items (lunch tray,hatch tent(?),roof racks,fog lites,seat bags,misc shades,etc.)
Brush Guard:(bull bar)Front(w/optional round PIAA fogs w/wire grillethat mount on a metal shelf of the brush guard).Has a lower ribbed rock shield.Aluminum.There's also a aluminum side step bar.It has 6 arms that attaches to the side skirt mounting points.It's purpose is only as a brush guard NOT to be stepped on.It'll most likely break off.
Cargo Cover
a)Soft roller cover.Looks like a pullout roller blind.48" wide with lots of small holes for the rear speakers.Interior width is about 53".Dealer installed option.
b)Hard Cover.Complete Upper & Lower storage compartments(w/doors).Similar to HB,but MUCH better.Also had optional speakers(near seat release knob).Located more forward than the speaker pod(mentioned below) .
Center Console(Armrest)with glove compartment with padded armrest door.Dealer option that attaches to your center console.
Front lower Console:Has a "cubby hole"(Some didn't have a cubby hole), ash tray & lighter.It attaches to the bottom of the radio & uses a different center console(looks like the usdm 1 except at the frt where it attaches to the frt.lower console.
Corner Lites. Front(Clear)See photo below..Rear (Amber with Red Stop lenses)
Cruise Control
Drag Coefficient:The lower the number the better.
.29 CRX '88 HF
.30 CRX(all except HF)
.33 HB(all even Si).'11 UK Jazz(Fit) w/new facelift.
.336 '08-'10 UK Jazz(Fit)
.35 Wagon
.35 '06-'08 Honda Fit(Jazz),'08 Tesla roadster, Del Sol,Mr2('98),'08 Mini
.37 Sdn DX
.38 Sdn. LX(probably due to extra weight & Pass mirror).
.38 Miata('89),subbie Forester('09)
Engine:4WD come with the Si engine.
Fog Lites.Front:Round(See lower pic). Rectangular (1's under the bumper parking lite)and/or Rears(RED).
Headlight(Cockpit adjustable):1990+Adjust for up & down.Uses a 1(hi/lo) bulb instead of 2.Servo motor is mounted a bit outboard of the bulb.Also found on 4 dr. sdn. & CRX(pretty sure ).
Floor Mats: Dealer option Carpet floor mats were available.They'll have "5 DR" molded on the back.The "CIVIC" logo embroidered on the front.Rubber with a 1"(25mm) lip all the way around.ribbed w/ Honda Name molded in.Set of dealer option front,rears & cargo area.Cargo area one is flat w/Honda name molded into the right rear corner & has a 3-4" lip.Won't look right in the USDM Wgn. 'cuz we don't have the side cargo storage compartments.
Headlight WashersSee pic below.
License plate mount:No side lic.lites for the wider Euro plate.The section between the reverse lites.
LSD.On '90+ 4WD:Front(confirmed by Haydz).Rear:It's a slnd.activated clutch-type.The viscous coupling was eliminated(between the 2 center drive shafts). Diff.housing is totally different from usdm 4WD diff.housing so LSD probably won't fit.That's why the Wagon Gas tank is different from the other Civic's to allow fitment of the larger diff. & better flowing exhaust.
The good news is Jaker fitted a 92-00 Civic D series FWD OBX LSD into the rear pumpkin(diff).All it took was to bore out the threaded ring gear bolt holes to blind holes, as the rear diff ring gear is threaded for the ring gear bolts as opposed to the diff being threaded.
Oil Pan/StorageIn 4WD only.It's a oil pan stuffed inside the spare tire.If you want one.The Integra pan will fit in the 2WD's spare.
Power Locks
Power MirrorsMight be folding too.
Power Steering has the fastest OEM Civic('88-'91)turning ratio.Faster than the CRX Si.Only a hair off the Teg.
Power Windows
Roof Rack
Seats(Power): Toogle switches on the side of seat below the tilt adj.handle.& Heated.Push button switches on lower centre console.
Seats(Rear):Base Wagon has a 1 piece vinyl reclinable adj. seat.The rest have a more comfortable 60/40 cloth NON-reclinable seat with adj. removable headrest.
Shocks:'96-'01 IntegraType R Rear shocks can be used on the 1988 Wagon only.Use the ITR lower shock bolt(improved design) too.This is the same bolt used in '92+ Civic/Integra (10x68mm) rear upper outer control arm.
Side Marker lite:amber
Speaker Pods:Rear.Dealer installed option.NOTE:Also see "Cargo Cover".
Speedo:150MPH(250KM/H)(you read it right-mph) & 9500 RPM(8000rpm redline) Tach.:arrow: It's from a '90-91 CRX 1.6i-VT(B16a),but I'm pretty sure it'll fit a wagon.
Storage DrawerIn 4WD's only.Located under the passenger seat.A Honda Odyssey storage drawer can be easily modded to fit(Honda part# 08U40-sx0-100)Also see oil pan.
Sunroof:Power
Window Bar:A metal bar that goes horizontally across the last side windows.It's purpose is unknown.Maybe to dry towels on?
Window Shade:Looks like a Ventican blind mounted inside for the rear hatch windows& rear side window.There are still aftermarket ones that even open/close.These days are good for the VIP scene.[/color]
Window Wind Deflectors(Frt.& rear doors).A Rear Wing Deflector(maybe a smoky grey) that somehow attaches to the rear wing that curves down pass the wing about 3-5".Is it a deflector or shade/combo is unknown.OEM or aftermarket?
Front Fog lites(limited edition Rti),clear corners & headlite washers.
Fog lites have a mounting bracket behind the lights which attach to a long bracket between the 2 lights.I believe this long bracket replaces the front bumper cover brkt.
ABS
Cargo Cover
Cruise Control
.29 CRX '88 HF
.35 Wagon
.37 Sdn DX
Power Locks
Power Windows
Roof Rack
Sunroof:Power
:oops: Sorry I rephrased it.The "Armrest"(refered to as the center console at times) is the most popular was a dealer installed option.To complete the JDM look you'll need the front lower console that goes from the radio to the armrest.
i was thinking ill make a panel to fill the gap or maybe make something to bring it off the floor
Did the JDM version of our wagons ever achieve such lofty speeds??
:shock:
180km/h on JDM
My comments in blue, just had to clear a few misconceptions up.
Thank you Pacifer for your updates.
Pacifer :
I've seen several on USDM Wagons & honda had sold them for $200.(No longer available)
I,ve seen several Wagons with sunroofs inJDM car lots.
this bumper is off of a 1994 (or 1995) Civic Shuttle RTi Limited Edition.
Thats mine, although you can't see heaps.
just manual folding ones, like on some HB's/CRX's
I don't think this bumper was only available on the intrac, I have seen two non intrac shuttles with the bumpers on them
in fact.. no USDM (and CDM??) models came with a sunroof from the factory
