RT4WD to AWD wtih Viscous Coupler
With the rt system it's very unpredictable and I'm trying to make it all wheel drive so that when I rally my wagon for racing it is more predictable. Because sometimes when I go into a turn I get under steer and if the RT system locks I get over steer an the rear end swings around so I'm trying to just eliminate that unpredictability with AWD. This is the application to be clear.
So from recent discussions with Bam on the Instagram I pretty much welded a dust shield to the outer casing of the viscous coupler. I installed the drive shaft after the weld and took it around the block. After the short test drive I check to see if it was still attached and it was to my surprise. Now I'm wondering if anyone else has tried this before? Am I wasting my time trying to do this with my stock drive shaft? Should I have a custom drive shaft made from trans to diff all one piece? Or go buy another drive shaft because I have royally F*** up this drive shaft. (Bam's opinion) Not like there's anything wrong with that.
If anyone has information about my application please shed light in this post in the form of constructive criticism. Just looking for guidance on this one.
Thanks.
Thanks.
would I? no, mine seems to light the rears up just fine launching.
but are you going to hurt anything? Maybe? Probably not. Did it improve anything? You tell us, do you feel like it handles better now?
i can agree prior to getting my 4wd back on in my car ( had to source driveline ) it handled like shit but now im powering thru all the turns practice makes perfect draw power from tranny make sure your shifting smoothly and using the clutch inline with brakes its all timing understeer sounds like a allignment / driver problem if anything.
one other thing to check is to see if your axles are slidng
can someone tell me what a solid driveline would do to the tranny and or diff? if i would have known that was a option i would have had a full line made instead of waiting 3 years to find a new line lol fml.
Are you guys road racing or rally racing?
I imagine rally.
Solid axle carbon fiber just saying.
I thought his wagon was RWD though?
Edit: From his wagon...got it.
I think that the solid shaft and stock rear diff from Jakers wagon took about 225hp/200tq, so I think a solid shaft would be ok. My only concern is using it as a DD on dry pavement a lot. Jaker seemed to think that the open diffs would allow for some 'play' in terms of forces on running a solid shaft.
I'm really curious about this now. Seems like LOTS of weight and complexity can be dropped out with a solid shaft.
I was really hoping for a solid shaft option that was normal, but not sure if this makes me feel better or worse. heh.
I've read some eclipse 1g forums talking about 1 piece options and they say as long as your yoke is aligned correctly the 1 piece works really well. I think in the end I'm still going to look for a 1 piece custom option and have a place make one.
DSS would make one for me for $1500 which I could stomach, but his suggestion was for off-road use only...literally not for a DD. PST said they wouldn't even make one for me.
Whelp.
throw a diff in the rear for the money, youll get more back out of it.
1. Not relying on a 25 year old part that's hard to find and has limited rebuild availability.
2. Reduction of weight in a rotating assembly.
3. A faster responding 4WD.
I think at this point I'm going to send my VC in for a rebuild (found a guy on ebay here in the US, http://www.ebay.com/usr/st3dave ) and buy an LSD as you suggested. Frank from DSS said there wouldn't even really be any weight savings by replacing the two shafts with CF pieces.
For the price that STE is currently charging ($350 ?), I'd suggest doing it yourself. The seals were about $30 (when I did mine) from Hercules Sealing Products
http://www.herculesus.com/
1 ea. Shaft Lip Seal Hercules #MOS-38X50X7TC
2 ea. Quad-ring Seal Hercules #QR-4325
1 ea. O-Ring Seal Hercules #MOR-94.4x3.1-90
I still have some of the 100,000 cSt PDMS (Polydimethylsiloxane), which is a little thicker than the stock fluid, providing quicker lockup. $50 plus shipping for enough to do 1 coupler. It's not rocket science, just a little time consuming. If you haven't already, read this thread:
https://www.civicwagon.com/showthread.php?9747-DYI-rebuilding-repair-RT4wd-Viscous-Coupler
Ok! Ordering parts now.
Toss me your paypal and I'll send you...$65? To cover shipping and paypal costs?
Thanks for pointing us in the right direction MrWhoopee. Hadn't even considered servicing the VC but, thanks to the thread shortcut and listed part #s you provided, all I have to do is print, order, and go to town on my VC. Much appreciated.
Sounds good, PM Sent
The method for filling the VC shown in the thread referenced above WILL NOT work with the correct PDMS fluid. It is much too thick to flow into the coupler. You must fully disassemble the stack, pour fluid into the housing (with shaft in place) and reinstall the plates individually to allow the trapped air to escape.
Once it is filled and closed up, remove the pipe plug from the end of the coupler opposite the shaft and stand upright (open hole on top) in an oven at 200 degress F. Bake for 3-4 hours, allowing the expanding fluid to escape thru the open hole (place a pan underneath to catch the escaping fluid). When no more fluid is exiting the VC, remove from the oven and allow to cool to room temp before replacing the plug. This will allow enough air into the unit to provide room for expansion of the fluid when the VC gets hot. Without this air, the fluid will force itself past the seals when it expands, potentially damaging the seals.
The maximum temperature for the seals is (IIRC) 240 deg., so I assumed the unit would not reach that temp.
And don't forget to laugh at the funny annotation at the last second of the video =D
For the time being I'll be rocking the wagon in 2wd.
I remove the 4 10mm bolts connecting to the back half of the drive shaft to access the 32mm nut.
then I removed the 32mm nut with a impact gun pretty easy.
then I just removed what was in my way.
Now I think I have got a point where I can put some welds down where my fingers are pointed.
Thinking about welding this up today. Hopefully this will work.
OH BABY!!! I am so excited to test this out.
Huston we have lift off.
Installed the driveshaft today, and from my first impressions its pretty awesome! I was able to find a parking lot with just a little snow dust. For the first time it felt predictable sliding sideways, and initiating the slide.
Pros: More predictable, RTAWD, More Responsive, MAD Launches.
Cons: Has that 4wd tight turn bind, probably worse gas mileage (update coming).
