91 DX daily project build
Bought the 91 DX in April 2014. Spent a loooong time looking for a daily to replace my DB8 Found this one on craigslist and scooped it up. 225k miles automatic with A/C.
Brought it home and immediately put my old wheels (Axis Maglites) on it and did a complete tune up (plugs,wires,cap and rotor) and oil change.
Did a couple junk yard runs and pulled a decent DA front lip for the rear, a couple miscellaneous screws and items and a Volvo 740 front lip. Also ordered replacement hatch struts, Broadway mirror and a password JDM wiper delete plug.
Put the DA lip on the rear, new hatch struts, and wiper delete plug on .
Worked on the 740 lip but still not sure about it.
Made another junkyard run and found an MK3 front lip. I liked the fitment much better than the Volvo lip and decided to mount it. Replaced the valve cover gasket set.
Ill get some pictures up tomorrow of the most recent mods.
Plans are pretty simple; Low and slow and more maintenance.
Front DA lip installed on rear. After installing it I realized the the mounting strip was broken from the actual lip and it makes it look uneven. Ill address the issue with some plastic epoxy and reinstall. I like the look just with is was a little taller.
Any ideas on some other rear lips?
Thats the MK3 jetta lip I installed. Worked out pretty good. Needed a little massaging from the heat gun and trimmed on the wheel well ends. I thought it fit pretty good and it looks 10x better with a front lip installed.
I still havent given up on the 740 lip, but its taking some time with the plastic epoxy and heat gun to get it where I want.
Ill update when they come in and I get them installed.
Keep up the work. I like the wheels. What drives me nuts is a 5 spoke wheel on a 4 lug hub. Even number spokes for even number lugs!
Here are some better pictures of the car.
Ended up cutting, fiberglassing, filling and sanding to get this:
Pretty happy with how it turned out. Tried my best to get it smooth and uniform looking. Painted it with Duplicolor trim paint.
Did the big three ground upgrade a little while back.
Spent several hours today taking old a/c evaporator and expansion valve and replacing it. Redid a lot of the foam sealer on the vents and put window screen on the top of blower motor housing. Got everything bolted up and ready for a re charge to get my a/c back up and running.
Just ordered new brake lines, fuel pump and coil overs.
Found a good deal on truhart basic coil overs so I'll be doing some follow up when they come in.
I'll update with pics when everything is back together.
Good work.The AC makes driving a lot more enjoyable .
I love your Honda wheels. They look so late 80's early 90's.
Post some photos once you install your new coil overs.
Broke off a nipple on the "two way valve" mounted on the tank next to the fuel pump.
On a plus side I got rear suspension off and have new bushings in top hats with coilovers mounted .
Long day
Now I'm left trying to figure out the importance of the two way valve and whether or not I want to try to find a replacement .
What color is that, anyway?
I only rode it around town to help settle everything and recheck bolts. To me the ride isnt overly harsh or rough compared to the 226k mile stock sspension. I had an integra with Koni / GC Off the shelf spring rates and Id say this is definately stiffer but nothing thats overly harsh or jarring.
Spring rates 8kg F / 7Kg R( ~ 448 lbs front and 392 lbs rear)
here are some before and after shots.
BEFORE:
AFTER:
Wrapped spoiler with 3M 1080 carbon fiber ...really like it and realized I am no professional wrapper
Good job on the wrapping.
I've been a little preoccupied with a ram d50 I recently got and have put the wagon to the side so to speak.
I have been kicking around the idea of getting drop LCA to help get the rear down more. http://mpcmotorsport.storenvy.com/products/12671569-drop-lower-control-arms
Need to get extended top hats and get the exhaust done.
Still digging it though!
http://www.truhartusa.com/Basic_Coilover_system_for88_91Civic_90_93_Integra_p/th-h701.htm
I dont drive it all that much since Ive got a company ride but I fall in love with it (and think of more things to do) everytime I do get to drive it.
Also I found a Honda car seat anchor for the wagon so I can tote the little monster around in it a little more securely.
Copped these bad boys at IA yesterday for more lowz!!!
Planning on installing the rest of the Noico sound deadening on the doors.
Need to get someone to deep clean the seats though.
Just trying to clean things up a bit.
