89 Civic Wagon Rear Trailing Arm Bushing Replacement? Help!
Hello guys! I am looking to replace my wagovan rear trailing arm bushings. I see some eBay ones which I am afraid to use because of it cheapness... I even thought about changing the whole trailing arm and do the rear disk convertion. Please guys give me a piece of advice in what is the easiest way and the best trailing arm bushing replacement. Thanks guys!
Updates: This is crazy guys! I lifted up my wagon and found out that I need:
* Left + Right Trailing Arm Bushings
* Left + Rifht Upper Control Arms Bushings
* Front Left Upper Ball Joint
* Front Right Lower Control Arm
* Rear Left Brake Cylinder
I installed the full eBay suspension kit last year (2 Upper Control Arms with Ball Joints and all the bushings, 2 Lower Ball Joints, 2 Outer Tie Rod Ends, 2 Inner Tie Rod Ends, 2 Sway Bar Link Kits (Stabilizer Link)). I do not want to keep waisting my money!!!......... Help!!!!!!!!!
http://www.youtube.com/watch?v=hPTDzrxqoOo
Okay, that is great! Do you happen to know the part number?? I looked online but I can only find the whole trailing arm....
By the way, that video makes the trailing arm bushing removal procedure a very easy one... I do not think so though...
Yes, the Dorman seems very good quality too.
Wow! Even with the removal tool? An hour? I also can not find the trailing arm bushing replacement online... They changed everything around... How much does it cost anyways??
Okay, that is another good option....
Rock Auto also has the Lower Control Arms complete with new bushings installed!
I see. I do not only need the bushing, but I need the whole thing.
Let me see if I could find the OEM one first and I will let you know....
Wow, thank you Zipperguts for all that information. It is very helpful. That is really cheap. I am going to compare some of the prices with the OEM ones and get the best deal. Dorman sees to make good quality parts....
Yes, there is a leak in the left hand side rear drum.... How much did you pay for the seal kit?
Wow, that is cheap...
this part# is a replacement to 52385-SR3-000 which had a recall
Thank you very much buddy! I was looking on the Honda Site and I could not find just the trailing arm bushing but the entire trailing arm... Thanks man!!
That is a great idea... I did not think about it... Thanks.
Yes, of course I am keeping my wagon... I actually got the OEM trailing Arm bushing (thank you driftin90 for the part number reference):
Oh my God! I got the wrong part number
Infact, that is the easiest way to remove all the bushings...and when you do the LCAs and you need to remove the aluminum sleeve that holds the rubber bushing, just cut into it a little bit as not to cut into the LCA itself...then hammer a flat head screw driver in the notch and try to pry one side to the center and eventually it will come right out.
Using a press is not necessary, although it is fun...wear boots if you do, they can break toes and feet
