GR33K's RT-4WD! Eye candy updates!
Alright, I am about to sell my old Wagon Stanley:
to make room for the new addition Charlie:
I purchased this from ZCPOWER_R.
And it took 11 hours each way to get this beast.
VA to Woodstock, GA and back.
Anyways that is the only picture I have right now, but I will have some more soon.
And A friend and I are doing the:
Timing belt
Water pump
Axle seals
Oil pump
Oil pan gasket
Valve cover gasket
4 O-rings at the bottom of the spark plug tubes
Rear crank seal
Steering boots
PS belt
AC belt
Alternator belt
And wiper blades... lol
And I have to give a huge shout out to bam-bam for helping wiring the radio in.
I would have gone insane on the way back without music for 11 hours!
Timing belt
Water pump
Axle seals
Oil pump
Oil pan gasket
Valve cover gasket
Rear crank seal
Steering boots
PS belt
AC belt
Alternator belt
it is hard both financially and time wise to keep one car let alone two or three.
Thanks! I need to do some things to it though to make it 'my own' though.
Thank you.
Thanks! I saw that it was for sale on 1/17 and snagged it 1/22. I was lucky that he held it for me till that weekend!
To a degree...
There are oil leaks in various spots (why I'm replacing a bunch of things)
One of the U-joints is bad in the drive shaft
Needs a windshield
Needs a new muffler and later new exhaust pipes
And it doesn't have a thermostat
But I am happy with the purchase, and what 23 year old car wouldn't have problems? lol
Ummm.... yes they are.
Not yet, I want to fix the new Wagon and then after I get it running properly I will start to sell the Blue one.
On the bright side, the clutch, flywheel, pressure plate, timing belt, and water pump proved to be young in age and we didn't have to replace them.
All we have to do is put the transmission back on, then everything will fall right in place afterwords. IT JUST WONT LINE UP! :evil:
I think I remember him having that clutch done recently.
I also have a question, I have Tokico suspension from a 94-01 Integra, but the fronts are too big to fit in the forks.
What forks can I use that will fit the Wagon and the suspension?
Thanks
Put a silver H on the front
Removed the mid-wing, HCW sticker, and Thule roof rack!
Removed the tint strip on the windshield
My lady got me OEM wheel locks for my birthday
And this is how the engine bay looks right now, well minus the tranny... I need to put it back together.
And the things done maintenance wise are: Axle seals, rear main seal, oil pan gasket, valve cover gasket, timing belt and water pump looked fresh so no need in doing that, as well as the clutch.
Thanks! I wish I could wash it, but I can't drive it. :roll:
If the car gets back together and passes inspection, I am going to sell it.
Parts installed since previous work: NGK plugs, NGK wires, fuel filter.
And as soon as the Wagon passes inspection, I will transfer over my seats and speaker pods from the blue Wagon
Some other items scored at the junkyard were:
Misc. nuts, screws, and bolts
Flywheel cover
Spare tire cover with foam attached to the metal (thought it would help with sound deadening)
Rear EF sedan 'Honda' mudflaps
Battery L shaped block off plate
Speedometer cable and clip
Bracket that goes on the stock airbox
Hood prop
I still need 1994-2001 Integra front suspension forks!!!!
And now my poem... lol
Oh Wagon Wagon Wagon,
When will you be done?
I’m tired of this nonsense,
When can we have fun?
Fuck you, fuck you, fuck you.
Oh Wagon, when will you stop being such a bitch?
If not soon, I am going to drive you into a ditch.
-Alex Eliopoulos
