High beam problems
hey everyone, my problem is when my low beams are both driver and passenger side work but when i turn on the highs only the driver side stays on. the passenger side high and low completely cut off and my bumper light comes on? is something grounding out? any help i can get is great thanks
Earth is refering to your body being a ground. I agree that you probably have chaffed wires and you will need to trace the wres and look over all of the wires near your lights that are giving issues. BTW, it's possible you do have a bad headlight switch assembly , happened to me on my old crx.
Wow! :?
