Gas coming back up filler neck
My car (89 dx with d16a6) wouldn't start this morning so I swapped out the ignition coil (found a little crack in the plastic housing) and decided to remove the evap cannister because I thought it might be a fuel problem. After that the car still acted the same, but after I floored it and turned it over for about 8 seconds straight it finally sputtered to life, ran like shit for a few seconds, then started to run normally. I just checked the fuel pressure and did the test on the fuel pressure regulator, everything seems to fine.
Now onto my very strange problem.... I thought maybe the car had been low on gas, so I went and filled up a 5 gallon gas can. When I took off the gas cap to try and put some gas in there, gas came gurgling up the filler neck and started pouring out onto the car! I also noticed that the longer the car runs for, the more quickly the gas gets expelled from the filler neck. So I guess somehow the gas tank is getting pressurized by air and is not able to let it escape? When I removed the evap canister I left the line going into the firewall open so it could vent, I ran my last civic this way for years with no problems. I plugged the intake manifold nipple that is now not used, as well as the nipple on the evap solenoid. I don't have my jack and stands here at the house, or I would go ahead and drop the gas tank down and take a look around at the hoses.
Does anybody know what could cause gas to forcefully come out of the filler neck like this? I'm also confused as to why the open hard line that goes through the firewall from the evap can isn't letting this pressure out of the system.
Not really sure what the problem was, but I drove the car around for about 20 more minutes and there was still no gas trying to escape the filler neck when I take the cap off. Also now my fuel gauge has seemingly started to work (usually it either just says half a tank or totally empty - either way it is wrong) and is registering 3/4 of a tank. Weird.
