Little Red Wagon
2
  • ReaccionReaccion Senior Wagonist
    bam-bam wrote:
    Reaccion wrote:
    bam-bam wrote:
    I don't want to jack your thread by sticking my car in it, but check out my build thread. Mine is raised on fatfives and 205/60/15 tires
    What roof rack did you use for yours?
    The roof rails are from a Kia Sportage, the rest is Yakima. It works well, but my wife's is better. On hers I used Ford Aerostar rails.[/quote:1qo53p6j]
    I want to buy a roof rack on eBay but I do not know which one? Bike, ski???
    Mine is a bike rack because it has 2 bike trays. You can mount ski/board/kayak/etc. attachments to the same round crossbars. Think of it as a modular system. Start with towers to fit your car, then add crossbars. All of the Yak accessories will then fit those bars. Check out their website and play with the fit guide- it will help you understand how it all works.
    cleaned things up a bit and replaced the head gasket
    Whoever worked on this before was a moron. I could see where he used some sort of abrasive wheel on a die grinder and gouged up the cylinder deck, and one of the head dowels was missing. I cleaned it up the best I could, maybe it'll hold.
    Changed the oil and filter 3x to get the sludge out, drove it around the neighborhood. Runs out well, needs brakes and maybe an axle.
    Oh, and the reason I just patched the engine? Picking up a d16z6 and a p28 tomorrow :)
    I need a P28!? :wink: Haha.
  • sometimesidosometimesido New Wagonist
    I want to see this thing running!
    Glad you got to drive it around the block!
    Okay, 'cause what I find great is that front panel that says Yakima on it. Would all Yakima kits (ski,bikes,etc) bring that front panel??? Thanks!
    That's called a fairing, and is sold separately for about $40. A lot of used setups will include one because the wind noise from the rack is SIGNIFICANTLY louder without it.
    Okay, I see. Oh, another thing, how many inches is that fairing? I was looking on eBay and they have different inches ones... Thank you very much... I am sorry but I am new on the Civic wagon world... I kind of lost... Thank you man...
    that wagon is balling Trev.
    red RT ftw
  • red RT ftw
    red RT wtf...
    :mrgreen:
    Well come see it, then!
    Update: drove it to work today, first time it's been driven further than around the neighborhood. It ran well, just needs a little love.
    Driver door doesn't want to open from inside.
    needs a window weatherstrip
    needs front brakes/rotors(came with it)
    rear brakes? maybe just an adjustment
    idles too low in gear
    need to put the rear propshaft back in
    So far the head gasket appears to be ok, no fluids mixing...
  • DarrenDarren Wagonist
    sweet, another bamtech success :)
    Here's a pic of the engine delivery truck
    this block does have the holes drilled and tapped
    bamtec vtec wtf
    After driving it to work just one day, I decided to fix the AC! Actually, my Dad is coming for a month-long visit starting may 4, and this will be his car while he's here. (Unless he picks something else!) He's forgotten more about cars than I'll ever learn, but he's 71 and I want him to be comfortable. He loves his EG sedan, so this should be familiar to him.
    First I removed the power steering pump and condenser fan, but left them connected. Just laid them back out of the way
    Now you can see the compressor
    Unbolted it, but it doesn't want to come up out of there. Removed the PS pump bracket.
    Cleaned up the area- what better time than now?
    Now, the reason I took the compressor off was to change the oil in it. This is not completely necessary, but is the best way to be sure what you have in there and how much. Turn the compressor upside down and drain the old oil out, occasionally rotating the compressor to help get it all out. A warm compressor will drain better- I used an incandescent droplight to help this one along.
    The textbooks say to measure the quantity of oil removed, and replace that same amount. From experience and with a calibrated eyeball, that's 4 oz. for these compressors. Use polyol ester oil. Just pour it in the low-side port a little at a time, rotating the clutch by hand in the normal direction of rotation to suck the oil in.
    Reinstall the compressor, using new o-rings at any joint you disturbed. Put all the other junk back on, then you're ready to play!
    Bought the adapter kit from Advance
    Then vacuumed the system for an hour or so. I elected not to replace the dryer, I haven't on any of these cars and they're fine.
    Added about 30 oz. of 134a, and she cools like a champ.
    Today I'll do exhaust, brakes....
  • show-off...
    :mrgreen:
    :P ^^
    Well, no pics today. I replaced the rear brakes, front rotors and pads. Reinstalled the driveline and re-engaged 4wd (disabled to tow home). Installed one of the stockish axle-backs I had (muffler was rusted out and no tips). Put all the plastic splashguard junk back on from the engine work. Put the LS meshies from my sedan on. Installed a Pioneer head unit I had here. Let's see, what else...
    Oh, yeah, idle was too low, especially with AC on, so I replaced the EACV. One from a b18a1 works just fine.
    Why'd you take the RT wheels off?
    Only temporarily! They are in need of new tires and a little restoration, meanwhile the meshies have brandspankingnew shoes on.
    I'm undecided about what size tires to get. I want something with a higher profile and maybe some knobbies 8)
  • Installed a Pioneer head unit
    Oh no not again so bust...ed...
    no pics...
    tsss...
    why am I talking too...
    !you
    :shock:
    Now with meshies- hated them on my other car, but I like on here
    what do you think? Stole them off my boat trailer 8)
    a little Georgia photochop fer ya
    I want meshes again BAD.
    You should bring that camper to the NW this summer ;)
    That's a bit far, I think. Meet us in Arkansas?
  • B!
    forgot to take a picture because...
    I was dazzled...
    and I had to watch the road...tooooohh...
    lol...
  • Liking the wagon wheels with the beauty ring .
  • 88 wago88 wago Wagonist
    LOWER IT :shock:
    hellno
