I just got CREAMED
lol well i just bought this EE2 last night. It drives ok needs a little work to be perfect. Im not gonna drive it for a while anyway. Its a 89 and its auto :(
any way here are the pic's
only rust i see so far.
to do list.
Get a new auto transmission
possibly a new motor since this one has 293k
brakes
front seats
fix rear seat
fix the little rust it has
clean interior
will add to list as i go along.
COST
Wagon-$700
Registration-$250
D15b2 replacement-$40
D15z1-replacement-$300
Auto-->manual swap-$200
obd0 dpfi-->obd1mpfi wiring conversion-$160
obd0-->obd1-$70
new/used distributor-$80
fuel rail-$15
ecu-$60
tune up stuff-$35
tow when tranny locked up-$75
replacement hf tranny $150
payed friend to help with swap x3 since it was my first time -$200
total so far= $2265
  • DarrenDarren Wagonist
    i love where the horn is... haha, looks like you got some work, but good body, rest is easy :)
    good luck & keep us posted .....
    Save the wagons!
  • Dash-N-CarsDash-N-Cars Senior Wagonist
    Pink seat covers FTW!!
  • where is the thermostat located on these?
    and how do i tell if my thermostat is bad?
    Good luck man! Save the cream! :D
  • Thanks Rev.
  • Welcome. Looks like you got your hands full. Keep us posted on the progress
  • any one of a manual in pdf format?
    The t stat is connected to the upper part of the lower radiator hose. Right where it connects to the back of the block. You can put it in a pot of boiling water with a thermometer, and see if it opens. Hope this helps
  • Here you go
  • :shock:!?wtf... honk that horn every now and then
    for cleaning that filter...
    :mrgreen:
    welcome... dont worry i know ur get these baby up and looking cute...
  • what is the black box sitting on the middle of the seat ?
    Looks like a distributor coil?
  • anyone have these wheels on there wagon? they are +40 offset. or any wheels that are +40 offset.
    http://www.rotawheels.com/wheels.asp?wheelid=14
  • ok so i found a ef service manual on hondaswap and would like to know if i can use this or do i need a wagon specific manual?
    www.civicwagon.com
    Those wheels would fit perfectly, fitment will not be an issue! I've seen a couple of guys sporting those wheels so...
    GL!! = )
  • SooEEf'nCreamySooEEf'nCreamy New Wagonist
    Yes another cream wagon!!! Welcome bro!!! Where in Socal do you live btw?
  • altadena. like 30 minutes from la.
  • bigluelokbigluelok Wagonist
    just pick up a stock d15b for 40 bucks that smokes a tiny bit but ill runn thcker oil and rebuild my stocker.
    pics later.
    I was going through a box of junk and found this, its a front plate relocater that i bought like 3 years ago from a h-t member.
    the wheels I plan on using for daily driving, just need to find 1 more wheel I let some one barrow it and they didnt return it. I will never do that again.
    my DA front shocks ant struts. will these work on the wagon?
    the Motor i bought for $40.00
    looks like a party to me...
    H*LLYEAH !!!
    :mrgreen:
    i have two bottlecaps for sale needs tires.if worse comes to worse.im in nor cal though.
    how much? shipped to 91001
    ill find out tomorrow.my work schedule is to messed up today.
    kool
  • atefcrxatefcrx Band Wagon
    Hey good luck with your wagon build. I have the same wheels for my wagon too but i want mine to be white.
  • wagobrad91wagobrad91 Wagonist
    looks like you've got some fun times ahead of you, and the caps are a good choice gotta go crazy with the color tho lol make em pop!
    www.civicwagon.com
    GL!! = )
    yea i'm running a set on my ride and there's another wagonist that has some too... check out the June voting of the PAC's
    so i turned my wagon on see if the fans would kick on and nothing so i started to take the intake tubing off and these wires were hanging
    i took the end caps off and hooked them both up the the battery and sure enough the fan kicked on.
    where do they go? i dont just want to wire it direct to the battery.
    i also found that my left corner has a hole in it.
    bump
