Finally a Civic Wagon New Parts!!!
Hi there,
Finally I have found a good civic wagon ( aka Shuttle ) in the Netherlands
now we can start with all the hard work.
Here are some picture of how it looks right now
and some parts that need to go on in the up coming time.
Parts list:
- set BBS 15Inch black
- set BBS 15Inch flat white winter tires
- set Tenzo Sinko 15Inch Toyo T1R
- JDM D15B vtec
- Innovative Mounts 65A
- Energy Motormounts Inserts
- Innovative Mounts traction bar
- Cusco brake stopper
- Set Bride Low max style seats
- FIA aprovved seat belts
- HKS Hipower catback
- MSD Blaster Coil 2
- MSD Distributor Cap
- NGK spark plug wires
- USR Full Size Radiator
First to do list:
- Fit my Bride replica seats again
- Put in my harness bar
- Try to get a nice rear wing installed, i'm still looking for the right one.
- Put in my JDM D15B vtec engine
- All MSD Stuff
- Energy Inserts
- F1 Spec Stage 2 Clutch
- F1 Spec3.8 kg Flywheel
- Civic EE9 front brakes 262mm
- Full Size Aluminium Radiator
- Mount the semi slicks on my Tenzo's
- Make the HKS catback from my EG6 fit on the wagon.
extra pictures will come soon on the Nurburg Ring next weekend
Parts list:
- JDM D15B vtec
First to do list:
- All MSD Stuff
- Energy Inserts
Have fun at the ring! Try and count the porsches! Just kidding that would be impossible.
the Skunk2 Coil where with the car when i got it.
We should have a Dutch wagon mini meet.
Dude you lucked out, all i got was 2 trash bags of garbage with mine.
Yes this is the old one from H22tch, he has my old civic EG now
and we are the company 12Tune and a good friend that will help me swap the engine in.
only like 1 or 2 small bits of rust.
and hope to get some nice pics soon
with this green,it looks like mine...logic,it's an european
i like the rims on first pics,it's Msw rims?
yeah!lower it with little tires! :twisted: 8)
so I order the following parts:
- Edelbrock Performer X Intake manifold.
- H22 trottle body
- AEM Black Fuel Rail
- P2R Trottle body gasket
- Edelbrock Intake gasket
- Walbro fuel pump
- greddy Spec 2 auto timer
- ACT Streetlight flywheel
- DC Sport 4-1 Header
and I'm still looking for a good cam for the D15B engine does any one has a tip?
greets Joey
Also will make a start to mount the Bride style seats.
pics will soon follow.!!
also installed bij Tenzo's
here are some Blackberry pics
Try a Bisi cam? http://www.bisimoto.com/
Level 1, D15B vtec billet
$349.00
Offers a 10% improvement in power over factory, emmisions friendly,stock-like idle, with emphasis on the 1500 to 5700 rpm range. Takes 7-10 business days to manufacture. Cam gear is recommended. 0.390" valve lift on the intake and 0.410"exh; 235 deg duration on intake and exhaust at 0.040"
Up to:
Level X, D15B vtec billet
$449.00
Professional use only. Offers over a 27% improvement in power over factory, with a lopey idle; emphasis on the 3500 to 8400 rpm range. Takes 7-10 business days to manufacture, from billet. Cam gears, EMS or carburetors, and our pro valve springs/retainers are a must.
now the wagon is standing still to get the D15B vtec in but i'm still waiting on some of my parts.
foto's from the ring will soon come..
my Edelbrock intake manifold and P2R gasket
today my new Skunk2 Front Camber kit Pro2 got in.
also the first stripping on the old engine we follow later today.
now the hard work can start
we're gonna make your wagon come back harder than ever.
I'm going to the shop tonight to work on your car 8)
see you saturday
thanks, and it will be nicer and a lot faster
Today my H22 trottle body came in and my other harness for the wire tuck.
Tommorow we are cleaning your new engine and start installing new parts
