Draft through driver's side vent
Hey guys,
I've noticed while driving, I've got a breeze coming through my driver's side vent. The one that you can move the knob to either let fresh air in or not. I've noticed it doesn't change whether it's open or closed. That is the only place I feel the draft...but being winter, I'm tired of it already. Anyone have any ideas of what's going on here?
Heat off: draft from outside
Heat on any setting to windshield or feet (not coming out of vents): draft from outside
notice the difference with heated air(knob left) or air from the outside (knob right)...
it that's not the case...happy hunting...
it applies to the passenger vent also...
not dual front middle vents...
so the draft...
is something else...
like Bam says...
and you'r sure the fanswitch
equals zero...
If after that you get a cold draft,then something is broke.
here's a little tip, if you want more airflow to the feet, you can plug the vents under the seats. there are little vents that blow underneath the seats for the rear, i plugged them to get more airflow up front.
hahaha
There is a combination of switches that makes it stop but i have no idea what they are now, too long ago.
My 56i does the same thing, I just ignore it and aim the air towards the window
This cable probably comes unhooked for some reason and just needs reattached.
Holy crap i remember that now. One day i was down there and saw it unhooked and i just put it back on.
glad to be of assistance...
dave
