Daytime Running lights in a canadian 91 Civic Si?
so the owners manual says i have it.
and i found this
but idk how to get them to work....so if you know anything about them lmk
and i found this
Goto the bottom & click on the Shop manual link(hopefully it still works).
It should help you diagnosis ur prob.
Good Luck
also almost everytime i turn them on the car chokes and the check engine light comes on very briefly then goes away. the car runs perfect before and after this happens
did you check the fuses under the hood?
