Intake manifold options for a 91?
Guys,
I'm intrested in throwing an intake on for some extra power. can i use any ebay brand intake? i have the D15B2 so the intake mani. looks weird as hell. should i hook a pipe up to the black box? would it even make a difference in power? thanks
Will
  • I don't know of a specific manufacturer that makes a bolt on DPFI intake but I'm sure you could modify one to fit. However, I would tell you to save your money and time and start looking for the parts to do a MPFI conversion instead.
    I pretty sure you use the same one that's used on the 88-91Civic's.I'm sure 1 of the other guys will verify this.
    You can use the one from MPFI but you may need to relocate the battery to the boot as the pipe will be sitting to the right about 2-3" further...
    I'd suggest doing an MPFI swap and then doing the intake/filter after that.. If you actually do the MPFI swap, try and source a intake manifold gasket that reduces induction temperatures.. :D
