my heater is on the fritz... S.O.S.
BillBoard
council member
yeah so my heater is on the fritz...
symptoms:
Does not blow air-
when hit bump or pot hole it will turn on for a second- but still weak
took out center consol and made sure everything was hooked up correctly
checked fuses
i got nothin...
Has anyone ever had this problem?
is there a Blower that is replaceable?
something about a heater core?
please help- im freezing my ass off down here...
symptoms:
Does not blow air-
checked fuses
i got nothin...
good luck, those blowers suck to change. you need little rubber hands/arms.
i'll check it out tommorrow...
umm is the glove box an easy dismantle...
thank you...
i hope your right
so i took out my glove box and am now reduced to beating the shit out of the white box, it turns the blower on but sounds very unhealthy...
im not sure what is the actual blower?
not sure what needs replacing?
i still need help-
any one ever replace a blower motor?
or know what it looks like?
Bread you can use to make sandwiches??? LOL !!
Seriously thought, I don't know what PITA refers to either. Please clarify.
last week i changed my steering colum joint + pedal box/assembly. serious PITA.
haha but yeah, P.I.T.A = Pain in the Arse, as said.
The white unit is what contains the heater fan.
but ya- this blower is a huge pain in the ass...
im rolling around with no glove box and swerving all over the road as i try to hit the blower with my fist/cellphone/remote/anything near and around me..
it totally works after you give it a beat down...
Cool, we have a "black box" in our cars...
speaking of which
is it possible that the blower motor can get weaker over time?
I'm thinkin its gettin weaker
will blower motors from any EF work on a wagon?
I used a HF blower on igotcrx's wagon?
will any NON EF blower motors workin
I'm in Canada and picked up an aftermarket blower motor for just over CDN$100. I'm in the process of trying to figure out how to replace it. I'm encouraged by what I've read here. I already had the glove box off and the bracket behind that, but need my real wrenches to remove a large bolt way at the back. I'm hopefull that with that removed, along with the clips in the front of the white enclosure (as it's been called here), the whole blower assembly will come apart (drop the bottom half). It appears one will need to do this to get the motor out, since there's a nut on the top of the blower fan that will make it impossible to remove the motor from the fan by dropping it down from the dash assembly.
I'll try to post some pics tomorrow.
Stily1, remove the whole blower housing from the car, THEN take it apart.
:x
Ahh, can't complain about that... everyday I see people excoriated for not searching first
I am referring to this post not the others bam-bam
Bottom line is, I installed a new blower motor and reinstated the dash/glovebox and it works like stink! Took all of my specialist wrenches/extensions/knuckle-bits to do it, though, and I did strip one screw (must pay special care to "righty tighty, lefty loosy" when upside down under the dash, dammit!). Turs out two out of three screws is good enough.
I'd attach some photos, but they're too large for this forum and I lack a good photo resizer.
