Installing headunit issue
Just wondering if there is a fuse for the radio, besides the one behind the headunit itself? Also, if there is which one is it on the fuse block?
Lastly, whenever I plug in the headunit my clock goes dim, also the door light on the cluster dimly flickers. When I press to turn on the headunit it turns on for a split second then turns off.
Any tips would be helpful. The original owner had her headunit in there no problem, then when I bought the car I took it out before I drove off. Lastly my clock always resets to 1:00 everytime I turn on the car.
Once again the help would be much appreciated, even schematics and fusebox layout.
