Jeremy's Okie Wagon #1 (Turbo Edition)
After finding this site several years ago I liked the look of the wagon and decided to purchase one for myself. That began the long, long, long search for a RT4wd wagon. I looked high and low search the internet local and long distance car lots even made a trip to california to find one. It was while on this trip to california when I received a call from a friend back home who had found on not more than 30 minutes from my house. I bought it sight unseen while in California I could not wait to get back. Here is what I found waiting for me when I got home.
Cleaned up engine bay
Cleaned up the engine bay
Used Fender from Salvage Yard
Installed a EF Hatch Back Lip.
«13
  • :mrgreen:
    love the progress already...
  • Okiewagon1Okiewagon1 Wagonist
    New front mudflaps
    New Pass mirror as mine did not come with one
    New parts not installed
    Yakima Roof Rack, EDM Side Markers and rear taillights
    Wagon on 16inch Rotas and lowered on EF Springs and no name coilovers. It sits way to low.
    EDM Rear Tails
    Roof Rack Installed with Bike
    Cleaned bay with AEM intake
    Fixing some of the Body work. Had a major dent on the pillar and door.
    Turbo coming next here is a mock up of a down pipe. I am going to be using an RB5 from a Mazda 626 and a BMC adaptar bracket.
    Downpipe for RB5 Turbo
    Forgot to mention that I also swapped out the A6 in favor of a low mileage Z6. Before I turbo'd. Also painted the block cast iron color and intake, valve cover is black. I also did a brake line tuck and wire tuck as well.
    Finished down pipe
    I drove it like this at 5psi for about a month. I origianally wanted to keep the ac with this setup but this would have taking another custom plate to space out the manifold from the block and turn the turbo. After doing some research I decided to save the money and buy the greddy kit made for the z6 that allows you to keep the ac and power steering. However as you may know these kits are made for the eg's so I new their would be some fabing involved. I also want to car to look like it is not turbo'd from the outside and once you pop the hood I also wanted to keep the stock raditator and condenser. All this without cutting the hard to find RT bumper. Posted below is how I put all of this together.
    Nice progress! How did the car feel after you installed the turbo?
    Well I went from the A6 to the Z6 first and that made a great difference. Had no problem with freeway entry speeds. Low end torque greatly improved. The main reason I switched to the Z6 is because my wife and i will be using this car to drive across the country this summer and i want a more reliable motor. I switch on a daily basis from a b16 Da Integra, to gsr crx, and a b16 crx and I wanted the wagon to be as fast as those cars. I knew that I did not want to ditch the 4wd setup in favor for a b series (although i do have plans to build a b 4wd wagon) so turbo seemed like the best option. I started putting together a "homemade" turbo kit and I wanted to keep the cost under 500. I was able to buy the turbo, bmc plate, hf manifold, turbo boost controller, boost guage, missing link and downpipe for 483 dollars.
    Once installed the car had great power. I was very impressed with this little turbo. I started making boost quickly and reached full boost by 2300 RPMS. Car made 168hp and 161tq. I didnt not get to run this setup and the track so I am not sure what times it could have put down. I am guessing high 14's low 15's. Here is more of the setup.
    Now my goal was to keep this car as comfortable as possible which would mean keeping the ac and power steering. This turbo manifold setup would not allow me to do this. So here comes the Greddy Kit.
    good work.
    i love home-made turbo kits.
    welcome to the site EERT.
    Totally sleeper. Set up looks good.
    How long are you going to run the missing link before you tune? That thing looks hella sick. I would sujest cutting out the fog light hole infront of the side mount but thats just me
    Thanks for the rundown. I don't have to worry about A/C since older cars here in Germany didn't come with A/C. Seeing these turbo wagons is going to make me get my lazy ass up off the couch and get the kit I have installed.
    Great work and again very nice progress.
    The car is currently down as I am installing a new greddy turbo kit. I had thought about cutting a couple of holes in the bumper to allow better airflow into the intercooler but I took a look at the rebar a notice that it had vents in the bar itself. So I added metal inserts to the rebar to push the air towards the intercooler. I also started on a vent on the bottom of the bumper that would push some air up into the intercooler as well. But before I completed the vent I decided to move to the Greddy kit. Here are some of the updated pics with the Greddy Kit.
    I hated this part cutting into my wagon but there really was no better way to route the as I wanted to keep the piping as short and direct as possible.
    Working on getting the ac condensor to fit
    To make everything fit like stock I had to move to a traction bar. Usually I would just make on of these as we do this inhouse however I happen to have a off brand one that I want to test out. I cut off the original radiator brackets off the car and moved new ones to the traction bar. I moved the radiator reward 2 inches and tilted it forward to match the original top mounting points. Now for the AC Condensor. I moved the condensor back 2 inches from its original mounting point and tilted it forward just like the rad. I also had to cut out a hole in the front cross member on the core support so the fitting for the line out would fit. This actually droped it quite a bit.
    Here you can see the condensor before I dropped it and cut the hole.
    Here you can see the fitting that I wanted to drop down.
    Fitting everything together
    Pic of the rad mount. You can see how it is tilted forward
    I prefer to make my own oil lines it is much cheaper. Here is a pic of the line.
    I seemed to be missing some pics so I am going to go retake some. I will post more latter.
  • yeezz man, this is fun to watch
    yes it is...
    :mrgreen:
    Greddy Turbo Kit
    Notice the AC compressor. In trying to keep the AC it became apparent that stock A6 compressor and bracket were to big. So I decided to use the Z6 units however i did keep the A6 Wagon condensor. This would mean that I am going to have to fab a few of the ac lines.
    Here is the AC Condensor. I decided it would be a good ideal to put foam on both sides just incase anything rubs.
    I then painted the whole thing with flat black.
    Here is the traction bar that I am using. It will work for now but I do have a new one I am building.
    You may have noticed from some of the pics that I decided to go with a different fuel setup. I did this to clean up the firewall alittle. Lines are stainless with AN fittings and a Earls 85micron fuel filter on the rail. The rail is AEM. I also decided to replace some of my water lines with stainless as well. The injectors are DSM 450's
    I am also running a Skunk2 manifold. Now for anyone that is thinking of buying this manifold for your wagon think again. I am not sure if it fits with the A6 but I had to use small head bolts on the IVAC so as not to hit the firewall. I am somewhat worried about engine movement and the manifold hitting the firewall so I will need to figure out what to do about that but as of now it clears.
    Back to fitment. I did have to trim quite a bit of the stock rebar.
    I also had to cut into the core support some.
    I also move the horns to the outside of the core support.
    I moved the power steering cooler to sit on top of the intercooler.
    Also installed a Accord Lip from a 94 on the front. I am still working on the back.
    Installed on car. Is that car turbo'd???????
    Everything looks good. Turbo does too. How does it run?
  • Fast-TechFast-Tech Band Wagon
    Nice job, man. Deff a killer sleeper.
    Right now I am tuned on chrome for 7psi but I have not driven with the new turbo. I am waiting for my bov to get in then I will be ready to go. I am so excited to drive this thing.
  • doitdubdoitdub familEE
    Wow this thing looks like like my dream wagon. Keep it up...
  • genedaddygenedaddy Wagonist
    what are the measurements on that intercooler? what did you remove to get it to fit? very clean looking!
  • 5th element5th element Band Wagon
    looks like a sleeper nice bro very nice
  • kamanari1kamanari1 New Wagonist
    so the ac wont work with the first turbo kit with the a6?
  • 89ac_EE289ac_EE2 Wagonist
    damn good to see another okie on here
  • teamolsteamols New Wagonist
    good pics and good job man. that was a great job on reworking the radoator and condensor
  • I decided not to install racing seats into the wagon because of comfort. They are so hard to get in and out of.
    Instead I decided to install del sol seats. They are so comfortable and the keep you well positioned.
    Here is a detailed list of what it took to get this done.
    What you will need.
    12mm and 14mm socket
    Welder
    Grinder/Cuttoff tool
    Drill and bit
    Marker
    Del Sol seats with sliders
    Start by removing your wagon seats. Then remove your sliders. The large/tall one that is closest to the door
    you can set this one to the side. We will work on this one latter. Take the smaller one that is the one
    closest to the ebrake. Remove the bracket from the slider. You can drill, grind, and use the cuttoff tool to
    accomplish this. There is only one.
    Finished product
    ignore the bottom bracket as you have not gotten this far let.
    Now take the corrsponding del sol slider and remove the brackets from it. There are two.
    Here is the bigger bracket removed.
    Here is the smaller one.
    You are now going to weld these onto the wagon slider. Start with the bigger one. This will go onto the back of the
    wagon slider. Just line it up to the back on the slider and use the holes that you drilled to get the slider
    off to weld the bracket to the wagon slider.
    Once Welded it should look like this.
    Now bolt this onto the del sol seat. Take the smaller bracket and bolt it to the del sol seat. Get it to lay flat
    on the wagon slider and mark it so that you can weld it to the wagon slider.
    Weld it on. Once finished it should look like this.
    Finished product bolted to Del Sol Seat.
    Now lets move onto the larger wagon slider and bracket and the del sol seat. There is a large bracket on the del sol seat.
    You can drill holes out on the bracket attached to the seat and bolt the wagon slider to it. Here are the holes I
    drilled.
    Then bolt wagon slider and bracket to del sol bracket
    Finished and both sliders and brackets bolted on.
    Installed in car. Dont worry I will take more detailed pics in the morning.
    Thats it. Now just repeat steps for other seat. Total install time should be about 2-4 hours. It took me longer
    to figure out just what I was going to do.
    Have fun and enjoy you new seats.
    What you will need.
    Welder
    Drill and bit
    Marker
    Finished product
    drilled.
  • Pics from this Year's trip to Mount Ida ARK
    Wagon loaded and getting ready to leave
    Wagon at Eufaula
    Back at the house with new head gasket that I didnt need
    Way in to ARK
    Arrived at Mount Ida around 11:00 AM.
  • Some off roading and river fun
    Me fishing on the river
    Bam and Me in the Kayak
    My Wife and me
    More fun in the river
    Crossing the river
  • So awesome....looks like you guys had a blast.
  • get them out of the water there drowning :cry: :wink:
    i miss my wagon :cry: :cry: :cry:
  • love the step by step on the seat install..
    also diggin on ur buddies wagotrailer..
    hopefull it wasnt a clean complete wagon when it got hacked up..
