condenser fan fuse keeps blowing.help.
I was driving home from work the a/c was perfect then it just started to blow hot air. I saw that the condenser fan wasnt turning on so i checked the fuse and it was blown so i thought i found my promblem. I put another one in with the same amperage and it blew as soon as i turned my a/c on. I tried it like 6 times using the same amps still nothing. It worked for a while when i put a 20 amp fuse but still blew after 10 min. But when i unplug the compressor power it dosent blow at all. Seems like it only when the a/c is functioning. Could it be my compressor? Please help.
