work in progress crv tranny comeing soon 56k beware
so far i got skunke2 dampers and coil overs camber kit, some 30 min exaust last minet stuff for deq but i like the way its sounds so it can stay, b20 for now but im sleeveing a ls-v-tec and boostin it stut bars front and back after market cross member moroso batt box with shut off and i also have the rt tranny and rear diff if anyone is looking for one the second gear grinds but other than that great shape
EDIT Just realised that your chassis is a FWD (shifter hole). I'd still go with the Wagon diff. I did this with some welding for the front mount on the rear diff, and just bolted in the RT4WD rear subframe for the back mount of the rear diff.
Turns out that the Wagovan transmission turns the driveshaft faster than I thought as well. The gearing that I did my calculations with was based on someone else's gear tooth count. I counted my own, and came up with 2.547:1, not 2.526:1 as I originally thought.
