ECU part number required
I may not get the answer i'm after but i need the full part number from an ECU out of a manual 1991 JDM EF7 CRX Si. It must be from this particular car. The part number should be like XXXXX-PM7-XXXX (in that format). Theres nine different choices that i have on picking my ECU and the '91 manual version has better fuel maps at low revvs, cleaner rev limit and reads the sensors slightly differently.
Thanks in advance!
  • This is the model number used for EVERY Honda ECU, no matter if you have an Integra, Civic, accord, etc. That number will always be 37820 and come first on the sticker. I've narrowed it down to these two.
    37820-PM7-000
    or
    37820-PM7-J001
    5spd, Japan, 88-91 ECU.. better fuel and ignition mappings.
    PM7 : 89-91 DOHC ZC (JDM 'EF' ECU)
    www.civicwagon.com
    It was PM7-905
